Undo [message #892984] |
Mon, 02 July 2012 04:32  |
I am having trouble with undo: It doesn't work correctly on Connections. If I create a new Connection in the diagram and undo that step, the Connection will be deleted from .diagram file as expected, but it will stay in the view (until I close and open it again). Could someone explain me how the undo works, to help me debug (I did not override it)? Can this be due to the update feature?
Re: Undo [message #894092 is a reply to message #893940] |
Fri, 06 July 2012 11:22   |
here my add Methode of the a connection (there are different ones, but one will do, as it is always the same problem).
* {@inheritDoc}
public PictogramElement add(IAddContext context) {
IAddConnectionContext addConContext = (IAddConnectionContext) context;
// TODO: Domain object
Rule addedDomainObject = (Rule) context.getNewObject();
ISprayStyle style = new RuleStyle();
ISprayConnection connection = new SimpleArrowShape(getFeatureProvider());
Connection result = (Connection) connection.getConnection(getDiagram(), style, addConContext.getSourceAnchor(), addConContext.getTargetAnchor());
// create link and wire it
peService.setPropertyValue(result, PROPERTY_MODEL_TYPE, CorePackage.Literals.RULE.getName());
link(result, addedDomainObject);
for (ConnectionDecorator conDecorator : result.getConnectionDecorators()) {
link(conDecorator, addedDomainObject);
setDoneChanges(true);
updatePictogramElement(result);
* My add:
* add false connections to enable collapse/expand
CustomContext ccontext = new CustomContext();
PictogramElement[] pea = new PictogramElement[2];
pea[0] = addConContext.getSourceAnchor().getParent();
pea[1] = addConContext.getTargetAnchor().getParent();
ccontext.setPictogramElements(pea);
ccontext.putProperty("type", "rule");
ICustomFeature[] cfs = getFeatureProvider().getCustomFeatures(ccontext);
for(ICustomFeature cf : cfs){
if(cf instanceof MyCreateFalseConnectionsFeature){
if(cf.canExecute(ccontext)){
cf.execute(ccontext);
return result;
and here is how the connection is created (getConnection Method of DottedArrowShape)
public Connection getConnection(final Diagram diagram, final ISprayStyle sprayStyle, final Anchor startAnchor, final Anchor endAnchor) {
final Connection newConnection = peCreateService.createFreeFormConnection(diagram);
newConnection.setStart(startAnchor);
newConnection.setEnd(endAnchor);
final Polyline polyline = gaService.createPolyline(newConnection);
polyline.setStyle(sprayStyle.getStyle(diagram));
// Define general layout of connection
polyline.setLineStyle(LineStyle.DASH);
// Set the Placings of the connection
ConnectionDecorator decorator = peCreateService.createConnectionDecorator(newConnection, false, 1.0, true);
List<Point> pointList = new ArrayList<Point>();
pointList.add(gaService.createPoint(-10, 10, 0, 0));
pointList.add(gaService.createPoint(0, 0, 0, 0));
pointList.add(gaService.createPoint(-10, -10, 0, 0));
Polyline element = gaService.createPolyline(decorator, pointList);
ISprayStyle style = sprayStyle;
element.setStyle(style.getStyle(diagram));
return newConnection;
FUDForum. Page generated in 0.30134 seconds
