[CDO 4.1] Get an exception when try to commit an EObject created from uml.ecore to CDO Server [message #893418] |
Wed, 04 July 2012 00:27  |
When I tried to commit EObject which was created from uml.ecore (Eclipse UML ecore), I got the following exception:
org.eclipse.emf.cdo.util.CommitException: java.lang.IllegalStateException: Package 'http://www.eclipse.org/uml2/2.1.0/UML' contains unresolved proxy 'platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//EModelElement'
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1148)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1154)
at my.test.model.uml.UMLDataGenerator.loadData_1(UMLDataGenerator.java:112)
at my.test.model.uml.UMLDataGenerator.main(UMLDataGenerator.java:29)
Caused by: java.lang.IllegalStateException: Package 'http://www.eclipse.org/uml2/2.1.0/UML' contains unresolved proxy 'platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//EModelElement'
at org.eclipse.emf.cdo.common.model.CDOModelUtil.checkCrossResourceURIs(CDOModelUtil.java:553)
at org.eclipse.emf.cdo.common.model.CDOModelUtil.writePackage(CDOModelUtil.java:528)
at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.write(CDOPackageUnitImpl.java:281)
at org.eclipse.emf.cdo.internal.common.protocol.CDODataOutputImpl.writeCDOPackageUnit(CDODataOutputImpl.java:89)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.requestingCommit(CommitTransactionRequest.java:150)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.requesting(CommitTransactionRequest.java:120)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.requesting(CDOClientRequestWithMonitoring.java:91)
at org.eclipse.net4j.signal.RequestWithMonitoring.requesting(RequestWithMonitoring.java:163)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedOutput(RequestWithConfirmation.java:117)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:296)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:102)
at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:233)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:51)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:433)
at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:87)
at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:73)
at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:108)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:512)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.commitTransaction(CDOClientProtocol.java:387)
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:72)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1134)
... 3 more
How to solve this problem ?
Thanks in advance.
Neung
[Updated on: Wed, 04 July 2012 00:48] by Moderator
FUDForum. Page generated in 0.03821 seconds
