Home » Language IDEs » ServerTools (WTP) » Invoking custom XMLContentAssistProcessor
Invoking custom XMLContentAssistProcessor [message #892822] Fri, 29 June 2012 18:15 Go to next message
Hi everyone,
I am failing to invoke my inherited class of my custom sourceViewerConfiguration class. As a result not able to invoke my inherited class of XMLContentAssistProcessor? These are the steps, which I have done. Please let me know, where I am going wrong?
My plugin.xml file
<?eclipse version="3.4"?>
<plugin>
<extension
point="org.eclipse.core.runtime.contentTypes">
<content-type
id="com.xyz.ide.core.contentType.dummy"
base-type="org.eclipse.core.runtime.xml"
file-extensions="xyz"
name="mypage"
priority="normal"
default-charset="UTF-8"/>
</extension>
<extension
point="org.eclipse.wst.sse.ui.editorConfiguration">
<sourceViewerConfigurtation
class="validation.MyStructuredXMLConfiguration"
target="com.xyz.ide.core.contentType.dummy"/>
</extension>
</plugin>
Is there something wrong in this plugin.xml file?
[Updated on: Fri, 29 June 2012 18:55] by Moderator
Re: Invoking custom XMLContentAssistProcessor [message #892827 is a reply to message #892822] Fri, 29 June 2012 22:39 Go to previous messageGo to next message
Unless you've copied and pasted wrong, the sourceViewerConfiguration element's name is misspelled in your file.
Re: Invoking custom XMLContentAssistProcessor [message #893314 is a reply to message #892827] Tue, 03 July 2012 10:07 Go to previous message
Thanks Nitin, yes that was the mistake.
Previous Topic:Prevent Eclispe content-assistance from xsd for the namespace, which is not declared in xml
Next Topic:unable to start jboss server eclipsce in debug mode
Current Time: Wed Jul 23 16:59:32 EDT 2025
Powered by FUDForum. Page generated in 0.03404 seconds
