Home » Modeling » TMF (Xtext) » EMF repository for Eclipse 3.5 and 3.6(Tycho build)
icon4.gif  EMF repository for Eclipse 3.5 and 3.6 [message #893284] Tue, 03 July 2012 09:04 Go to next message
I am working on an Xtext based eclipse product and before the Juno release, I was able to build my product for Eclipse 3.5, 3.6, 3.7 and 3.8 with the help of Tycho.
As my product needed fixes brought by Xtext 2.3, I used the latest Xtext P2 repository in my target files.
Since 2.3 is out, I decided to switch to the release repository but it appears that Xtext expect EMF >= 2.7.0 and the latest P2 repo seems to have also the latest version of EMF which is not the case for XText releases repo.
Unfortunately, it seems the EMF project does not provide P2 repos anymore since it is now part of the Eclipse release train.
So my build now works only for Eclipse 3.8 and 3.7 (since their respective repositories contains EMF >= 2.7.0) but I have a problem with Eclipse 3.6 and 3.5.
I tried to add the Juno P2 repo for Eclipse 3.5 and 3.6 but I now have failures in tests (it seems Tycho uses latests SWT and this causes the failures).
Do you know if I can find EMF P2 repo somewhere ?
Jeff
Re: EMF repository for Eclipse 3.5 and 3.6 [message #893294 is a reply to message #893284] Tue, 03 July 2012 09:26 Go to previous messageGo to next message
That's not true, Xtext is build with eclipse galileo (3.5.2) and emf 2.5, so expect emf >= 2.5
... it's also not true. EMF is probably the first project that was on the train and therefore it also included in the galileo repository (http://download.eclipse.org/releases/galileo). And we also have a separated repositories since >=2.6 (download.eclipse.org/modeling/emf/emf/updates/(2.6|2.7|2.8)/.
Prio 2.6 there is a common emf repository (download.eclipse.org/modeling/emf/updates) which contains EMF SDK from 2.0.6 to 2.5.0.
Re: EMF repository for Eclipse 3.5 and 3.6 [message #893295 is a reply to message #893284] Tue, 03 July 2012 09:27 Go to previous messageGo to next message
... posted twice Sad
[Updated on: Tue, 03 July 2012 09:28] by Moderator
Re: EMF repository for Eclipse 3.5 and 3.6 [message #893324 is a reply to message #893294] Tue, 03 July 2012 10:42 Go to previous messageGo to next message
Xtext is build with EMF 2.5 but if I use EMF from either galilo or helios, I have compilation errors in my grammar files (Xtext generation is performed using Eclipse 3.7)
We agree on this point, I just wanted to say that using the release train repo was the only source I found for getting EMF
Re: EMF repository for Eclipse 3.5 and 3.6 [message #893334 is a reply to message #893284] Tue, 03 July 2012 11:14 Go to previous message
EMF like many projects provides manual downloads at
http://www.eclipse.org/modeling/emf/downloads/?project=emf
Ed Willink
> releases repo. Unfortunately, it seems the EMF project does not
> train.
> failures).
> Thanks
> Jeff
Previous Topic:Inconsistent stackmap frames error leading to broken code generation
Next Topic:IXtextDocument.modify consumes all preceding white space
Current Time: Fri Jul 25 21:51:20 EDT 2025
Powered by FUDForum. Page generated in 0.28066 seconds
