Home » Modeling » TMF (Xtext) » How to use xtext inferred JVM model outside of xtext project?
How to use xtext inferred JVM model outside of xtext project? [message #892716] Fri, 29 June 2012 06:36 Go to next message
In the **Inferring a JVM Model** section of the Xtext documentation it starts by saying:
"In many cases, you will want your DSLs concepts to be usable as Java elements. E.g. an Entity will become a Java class and should be usable as such".
In the example above, how can I use the generated Entity class **outside** of xbase, i.e. in real Java code in a different project to the xtext one?
What I am essentially asking is if the Java classes created my by the model Inferrer can actually be used as real java classes, which can have their methods called and fields accessed from java code, in an altogether different project, and if so how this can be done?
My going through the documentation has lead me to fear that the generated "Java classes" are only Xbase types, only referenceabe in an xtext context, and are not therefore real java classes...
Re: How to use xtext inferred JVM model outside of xtext project? [message #892952 is a reply to message #892716] Mon, 02 July 2012 03:07 Go to previous messageGo to next message
When using Xbase as described in the docs, it will automatically
generate Java classes from your DSL artifacts. It's these classes that
are referrable by Java.
In contrast to the traditional model > text code generation approach, in
Xbase you define a transformation of your DSL model to a Java model. As
the Java model is comprehensive, the Xbase infrastructure can generate
the Java code from it.
Am 29.06.12 12:36, schrieb Marcus Mathioudakis:
> starts by saying:
> as such".
> the xtext one?
Re: How to use xtext inferred JVM model outside of xtext project? [message #892966 is a reply to message #892952] Mon, 02 July 2012 04:01 Go to previous messageGo to next message
Ok so it gererates the classes, but how do I access them? I'm assuming you mean it loads them into the JVM (as opposed to actually generating code for them) but then how do you refer to them? I can't seem to find any kind of service for doing thihs, or an example of someone inferring a JVM model, and then referring to the resulting Java classes from a java context.
[Updated on: Mon, 02 July 2012 04:03] by Moderator
Re: How to use xtext inferred JVM model outside of xtext project? [message #892967 is a reply to message #892966] Mon, 02 July 2012 04:01 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 02 July 2012 04:02] by Moderator
Re: How to use xtext inferred JVM model outside of xtext project? [message #892993 is a reply to message #892966] Mon, 02 July 2012 04:49 Go to previous message
No, it generates Java source code that is picked up by JDT and thus
compiled. At execution time, it is only the Java class file that is
executed.
Am 02.07.12 10:01, schrieb Marcus Mathioudakis:
> java context.
Previous Topic:how to create reference for xtext
Next Topic:Crossreferences in an embedded editor
Current Time: Mon Jul 21 12:07:57 EDT 2025
Powered by FUDForum. Page generated in 0.08359 seconds
