Home » Modeling » EMF » [xcore] xml
[xcore] xml [message #892892] |
Sun, 01 July 2012 10:09  |
I try to use xml instead of xmi to save my ecore model. I use xcore to define the model but i can
not find a way to generate xml.
here my example
@GenModel(resource="XML", editDirectory="/test.xcore.edit/src",
editorDirectory="/test.xcore.editor/src", fileExtensions="xc", generateSchema="true")
package test.xcore
@ExtendedMetaData(kind="elementOnly", name="ROOT")
class RootElement
@ExtendedMetaData(kind="element", name="CHILDS")
contains Child [] child
@ExtendedMetaData(name="ChildClass")
class Child
@ExtendedMetaData(kind="attribute", name="nameAttribute")
String name
Could any one give me a hint what I am missing?
thanks, Martin
Re: [xcore] xml [message #892893 is a reply to message #892892] |
Sun, 01 July 2012 10:39   |
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
Martin,<br>
<br>
Comments below.<br>
<br>
<div class="moz-cite-prefix">On 01/07/2012 4:09 PM, Martin Jacob
wrote:<br>
</div>
<blockquote cite="mid:jsplnm$pd8$1@xxxxxxxxe.org" type="cite">Hi,
<br>
<br>
xcore to define the model but i can not find a way to generate
xml.
<br>
</blockquote>
What do you mean by generate XML? When I generate the tests project
and run the generated example, I get the following:<br>
<blockquote><?xml version="1.0" encoding="ASCII"?><br>
<xcore:ROOT xmlns:xcore="test.xcore"/><br>
</blockquote>
So that looks to be what's expected...<br>
<br>
here my example
<br>
<br>
<br>
<br>
package test.xcore
<br>
<br>
<br>
class RootElement
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
class Child
<br>
<br>
<br>
String name
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
Is your file extension registered in the plugin.xml (keeping in mind
that the plugin.xml doesn't regenerate once it exists).<br>
<br>
thanks, Martin
<br>
</blockquote>
<br>
<br>
</body>
</html>
Re: [xcore] xml [message #892895 is a reply to message #892893] |
Sun, 01 July 2012 11:05   |
Thanks Ed,
yes I wan to get what you got but I get:
<xcore:RootElement xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xcore="test.xcore">
<child/>
<child/>
<child/>
</xcore:RootElement>
I deleted the edit and editor projects to generate them new from scratch but still getting the XMI
as above.
I also deleted the generated model code in src-gen folder to generate them once more but this did
not help.
Do I need to change any thing else in the project setup than setting the @GenModel(resource="XML")
in the *.xcore file?
I am using latest eclipse (4.2.0).
Martin
Ed Merks wrote, On 01.07.2012 16:39:
> Martin,
> Comments below.
> On 01/07/2012 4:09 PM, Martin Jacob wrote:
>> Hi,
> What do you mean by generate XML? When I generate the tests project and run the generated example, I
> get the following:
>> here my example
>> package test.xcore
>> class RootElement
>> class Child
>> String name
> Is your file extension registered in the plugin.xml (keeping in mind that the plugin.xml doesn't
>> thanks, Martin
Re: [xcore] xml [message #892899 is a reply to message #892895] |
Sun, 01 July 2012 11:48   |
Martin,
What's in your plugin.xml for the model?
<extension point="org.eclipse.emf.ecore.extension_parser">
<parser
type="xc"
class="test.xcore.util.XcoreResourceFactoryImpl"/>
</extension>
Does your resource factory look like this:
public Resource createResource(URI uri)
XMLResource result = new XcoreResourceImpl(uri);
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA_LOCATION,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LEXICAL_HANDLER,
Boolean.TRUE);
return result;
On 01/07/2012 5:05 PM, Martin Jacob wrote:
> Thanks Ed,
> <child/>
> <child/>
> <child/>
> scratch but still getting the XMI as above.
> them once more but this did not help.
> the @GenModel(resource="XML") in the *.xcore file?
> Martin
>> Martin,
>> Comments below.
>>> Hi,
>> get the following:
>>> here my example
>>> package test.xcore
>>> class RootElement
>>> class Child
>>> String name
>>> thanks, Martin
Re: [xcore] xml [message #892902 is a reply to message #892899] |
Sun, 01 July 2012 12:19  |
thanks Ed,
the missing part in my setup was the below mentioned extension in my model plugin.
thanks again, Martin
Ed Merks wrote, On 01.07.2012 17:48:
> Martin,
> <parser
> type="xc"
> </extension>
> result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA_LOCATION, Boolean.TRUE);
> result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE, Boolean.TRUE);
> result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE, Boolean.TRUE);
> result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LEXICAL_HANDLER, Boolean.TRUE);
> return result;
>> Thanks Ed,
>> <?xml version="1.0" encoding="UTF-8"?>
>> <child/>
>> <child/>
>> <child/>
>> as above.
>> not help.
>> Martin
>>> Martin,
>>> Comments below.
>>>> Hi,
>>> get the following:
>>>> here my example
>>>> package test.xcore
>>>> class RootElement
>>>> class Child
>>>> String name
>>>> thanks, Martin
Current Time: Thu Jul 24 23:22:05 EDT 2025
Powered by FUDForum. Page generated in 0.35363 seconds
