Home » Modeling » Papyrus » Juno: code errors in generated model code of static uml profile
Juno: code errors in generated model code of static uml profile [message #892714] Fri, 29 June 2012 06:29 Go to next message
I'm porting a static profile from indigo to juno release.
I have already updated all changed extension points and references inside the uml profile. But when generating the model code from the genmodel, I experience a case error in the PackageImpl class (see below). It is easy to correct by hand and the profile works fine afterwards, but annoying as the error reappears every time the model code is generated again. Did I miss something while porting? Is there any way to fix this?
In the following snipped org.eclipse.uml2.types.typesPackage should actually be org.eclipse.uml2.types.TypesPackage. The line wasn't even there in indigo.
	 * Complete the initialization of the package and its meta-model.  This
	 * method is guarded to have no affect on any invocation but its first.
	 * <!-- begin-user-doc -->
	 * <!-- end-user-doc -->
	 * @generated
	public void initializePackageContents() {
		if (isInitialized) return;
		isInitialized = true;
		// Initialize package
		setName(eNAME);
		setNsPrefix(eNS_PREFIX);
		setNsURI(eNS_URI);
		// Obtain other dependent packages
		UMLPackage theUMLPackage = (UMLPackage)EPackage.Registry.INSTANCE.getEPackage(UMLPackage.eNS_URI);
		org.eclipse.uml2.types.typesPackage thetypesPackage = (org.eclipse.uml2.types.typesPackage)EPackage.Registry.INSTANCE.getEPackage(org.eclipse.uml2.types.typesPackage.eNS_URI);
		SystemViewPackage theSystemViewPackage = (SystemViewPackage)EPackage.Registry.INSTANCE.getEPackage(SystemViewPackage.eNS_URI);
Re: Juno: code errors in generated model code of static uml profile [message #892844 is a reply to message #892714] Sat, 30 June 2012 07:22 Go to previous messageGo to next message
Christian,
I think this is a problem with the latest version of the UML2.genmodel,
which treats this types packages as kind of a built-in model for which
it produces a GenPackage wrapper automatically. I suspect it's not
initializing the GenPackage's prefix property properly. Please open a
bugzilla against UML2.
> there in indigo.
> This
> first.
> * @generated
> setName(eNAME);
> setNsURI(eNS_URI);
Re: Juno: code errors in generated model code of static uml profile [message #892848 is a reply to message #892844] Sat, 30 June 2012 08:41 Go to previous messageGo to next message
Are you specifying Types.genmodel as a used gen package? If so, this
looks like a justification for reopening
https://bugs.eclipse.org/bugs/show_bug.cgi?id=366348.
The intention is that the Types package is a hidden secret, so that
users should not notice a UML2 3.0/4.0 change.
Ed Willink
On 30/06/2012 12:22, Ed Merks wrote:
> Christian,
> UML2.genmodel, which treats this types packages as kind of a built-in
> model for which it produces a GenPackage wrapper automatically. I
> suspect it's not initializing the GenPackage's prefix property
> properly. Please open a bugzilla against UML2.
>> there in indigo.
>> meta-model. This
>> first.
>> * @generated
>> setName(eNAME);
>> setNsURI(eNS_URI);
Re: Juno: code errors in generated model code of static uml profile [message #895751 is a reply to message #892848] Sun, 15 July 2012 13:44 Go to previous messageGo to next message
See also https://bugs.eclipse.org/bugs/show_bug.cgi?id=382637.
Ed Willink
On 30/06/2012 13:41, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> Christian,
>>> meta-model. This
>>> first.
>>> * @generated
>>> setName(eNAME);
>>> setNsURI(eNS_URI);
Re: Juno: code errors in generated model code of static uml profile [message #920707 is a reply to message #892714] Sun, 23 September 2012 06:48 Go to previous message
Is there a solution for this problem? Or at least a bugzilla entry for it?
Christian
Previous Topic:Wrapped rather than Truncated Text for Use Case Names in Use Case Diagrams
Next Topic:Control / UnControl not visible in the Model Explorer Context Menu
Current Time: Thu Jul 24 21:51:05 EDT 2025
Powered by FUDForum. Page generated in 0.06612 seconds
