Home » Archived » BIRT » White space where rows are empty(Inner table is sparse, outer table displays white space for empty rows)
White space where rows are empty [message #892241] Wed, 27 June 2012 09:26 Go to next message
I have a problem with spacing inserted into my report that I can't see how to remove.
My report is a complex one, with data in a table that is derived from another outer table via database queries: I have produced a simple example using the sample database.
The outer table has more rows than the inner table: the inner table is filtering to only display data for some of the values in the outer table.
No data from the outer table is displayed, but somehow a small amount of space is inserted for each row in the outer table, between the data from the inner table.
In the example at https://dl.dropbox.com/u/25811739/innertablespacing.rptdesign the outer table background is set to white, the inner table background to green.
If you scroll down the report you will see there is a variable amount of white space, I'm guessing a couple of pixels width for each empty row in the outer table.
In my report, the outer table has a large number of rows, the inner table only a few, with the result that there are pages of blank space between entries.
I've removed all padding, suppressed duplicates, set 'show if blank' to false. What can I do to remove all the white space?
Colin
Re: White space where rows are empty [message #892555 is a reply to message #892241] Thu, 28 June 2012 11:36 Go to previous messageGo to next message
Colin the issue is that the outer table element is writing a row out
even when the internal table does not. Can you try the outer table as a
list instead. See attached.
Jason
> how to remove.
> the inner table.
> In the example at
> the outer table.
> between entries.
> Colin
Re: White space where rows are empty [message #892649 is a reply to message #892555] Thu, 28 June 2012 20:50 Go to previous messageGo to next message
In my report I am passing a global variable with a beforeopen for the
dataset of an inner table via the on create for each row of the outer table
(an earlier suggestion of yours I have used in several reports). The detail
row of the list has no script methods, so I can't use a list.
Colin
> Jason
> how to remove. My report is a complex one, with data in a table that is
> simple example using the sample database. The outer table has more rows
> for some of the values in the outer table. No data from the outer table
> In the example at <a
> href="https://dl.dropbox.com/u/25811739/innertablespacing.rptdesign">https://dl.dropbox.com/u/25811739/innertablespacing.rptdesign</a>
> to green. If you scroll down the report you will see there is a variable
> entries. I've removed all padding, suppressed duplicates, set 'show if
> Colin
Re: White space where rows are empty [message #892801 is a reply to message #892649] Fri, 29 June 2012 14:14 Go to previous messageGo to next message
What kind of data set is the inner one? Does it have data set parameters?
Jason
> Colin
>> Jason
>> Colin
Re: White space where rows are empty [message #892881 is a reply to message #892801] Sun, 01 July 2012 03:43 Go to previous messageGo to next message
I found a work-around: I copied the data from the inner table to a scripted data set, then displayed that and set the other tables invisible.
Colin
Re: White space where rows are empty [message #893149 is a reply to message #892881] Mon, 02 July 2012 18:14 Go to previous message
Thanks for the update.
Jason
> Colin
Previous Topic:pdf generator's source code
Next Topic:BIRT support for PDF and Excel report Generation
Current Time: Wed Jul 23 01:58:32 EDT 2025
Powered by FUDForum. Page generated in 0.04948 seconds
