Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Standalone generation
[Acceleo] Standalone generation [message #880046] Fri, 01 June 2012 06:34 Go to next message
I'm trying to call acceleo generation without eclipse.
I got the error "package with uri "*" not found" which I resolved by adding the following line in the registerPackages function :
resourceSet.getPackageRegistry().put("metamodel.ecore", EcorePackage.eINSTANCE);
where "metamodel.ecore" is my metamodel.
But then I have a new error :
"Class 'App' is not found or is Abstract (file :***/app.xmi)"
where 'App' is a class from my metamodel, the class from which I created my model 'app.xmi'.
I tried to add lines in the 'registerResourceFactories' function like :
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
But this doesn't change anything. Any idea ?
Thank you.
Re: [Acceleo] Standalone generation [message #885099 is a reply to message #880046] Tue, 12 June 2012 09:19 Go to previous messageGo to next message
With your ecore model, you should have a genmodel and the generated Java code. In this Java code, you should have a subclass of EPackage. You need the following code:
resourceSet.getPackageRegistry().put(MySubClassOfEPAckage.NS_URI, MySubClassOfEPAckage.eINSTANCE);
The following code would help to load the code of your model (in the case of xmi models):
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: [Acceleo] Standalone generation [message #892763 is a reply to message #885099] Fri, 29 June 2012 10:14 Go to previous messageGo to next message
Thanks for your response,
Why should I have a genmodel ? I don't use one with my ecore meta-model.
With my meta-model, I only create dynamic instances of it, this instances are xmi models.
Then I use these xmi models as input for acceleo generation. Now I'm trying to do the same thing in standalone, isn't it possible ?
[Updated on: Mon, 02 July 2012 07:58] by Moderator
Re: [Acceleo] Standalone generation [message #893180 is a reply to message #892763] Tue, 03 July 2012 02:24 Go to previous messageGo to next message
In the absence of a response from the Acceleo guys....
It should not be necessary to have a genmodel, and I think I do some
Acceleo transformations without one.
I found it almost impossible to do standalone transformations with
Acceleo version 3.1.3, 3.2.*, 3.3 prior to RC6.
Make sure you're either using 3.1.2 or earlier or the Juno 3.3 release.
Ed Willink
On 29/06/2012 15:14, Cyril Savary wrote:
> Thanks for yout response,
> Why should I have a genmodel ? I don't use one with my ecore model.
> With my metamodel, I only create dynamic instances of it, this
Re: [Acceleo] Standalone generation [message #893784 is a reply to message #880046] Thu, 05 July 2012 09:55 Go to previous message
I've been using acceleo in a standalone app for some time now, including 3.1 and 3.2 releases... It's "simply" a matter of chasing missing jars at runtime... Smile
[Updated on: Thu, 05 July 2012 09:55] by Moderator
Previous Topic:[Acceleo] Java services
Next Topic:org.eclipse.acceleo:maven:jar:3.2.1 not found
Current Time: Wed Jul 23 05:35:24 EDT 2025
Powered by FUDForum. Page generated in 0.04625 seconds
