How to remove windowbuilder components? [message #892651] |
Thu, 28 June 2012 21:46  |
Hello everyone,
I am going to design a software which can render the UI of exsisting java source files.
Thanks to WindowBuilder that it provides this functionality.
But because this is my first time to modify WB, so I have some problems and questions.
- Can I run window builder standalone?
- Can I just use the basic engine for just disply UI from exsisting java file? No other functionality.
Actually i do not need and drag and drop or making new components. I just want windowbuilder to show the GUI and when I click on any component of GUI it will show me its properties thats all.
Can any one hepl me out in this? I will be really greatfull. Thanks
Re: How to remove windowbuilder components? [message #892945 is a reply to message #892935] |
Mon, 02 July 2012 02:12   |
Now I have tried to run WindowBuilder form Tests packages. I have opened plugin.xml file and run this by pressing play icon on top right of window. New Eclipse instance has started and i have created new java class with JFrame. After switching this class into Design mode i have got the following exception
eclipse.buildId=M20120208-0800
java.version=1.6.0_20
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data D:\Projects\GUIRender\CCJK/../runtime-EclipseApplication -dev file:D:/Projects/GUIRender/CCJK/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.core.resources 2 10035 2012-07-02 14:03:29.439
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jface 2 0 2012-07-02 14:03:34.005
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2012-07-02 14:03:34.005
!MESSAGE A conflict occurred for CTRL+3:
Binding(CTRL+3,
ParameterizedCommand(Command(com.test.email.openMessage,Open Message Dialog,
Open a message dialog,
Category(com.test.email.category,Mail,null,true),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(CTRL+3,
ParameterizedCommand(Command(org.eclipse.ui.window.quickAccess,Quick Access,
Quickly access UI elements,
Category(org.eclipse.ui.category.window,Window,null,true),
org.eclipse.ui.internal.quickaccess.QuickAccessHandler@1ee71ac,
,,true),null),
java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:626)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:608)
FUDForum. Page generated in 0.04783 seconds
