Problems with Papyrus 0.9.0 [message #876272] |
Thu, 24 May 2012 05:34  |
I tried different Versions (M6 and RC1) of Papyrus. In both Versions there is a problem with Activity Diagrams. In M6 I was not able to connect nodes with control flow, e.g. Opaque Actions with other Opaque Actions. In RC1 I cannot even create an Activity Diagram via the Papyrus Model Wizard. It creates a model.di file but I cannot open this file (I guess because the other files are not generated).
The stacktrace is:
at org.eclipse.papyrus.infra.core.utils.ServiceUtilsForActionHandlers.getServiceRegistry(ServiceUtilsForActionHandlers.java:70)
at org.eclipse.papyrus.infra.core.utils.ServiceUtilsForActionHandlers.getTransactionalEditingDomain(ServiceUtilsForActionHandlers.java:88)
at org.eclipse.papyrus.infra.emf.utils.EMFHelper.resolveEditingDomain(EMFHelper.java:190)
at org.eclipse.papyrus.uml.diagram.common.helper.PreferenceInitializerForElementHelper.initBackgroundFromPrefs(PreferenceInitializerForElementHelper.java:102)
at org.eclipse.papyrus.uml.diagram.activity.providers.UMLViewProvider.createActivity_2001(UMLViewProvider.java:547)
at org.eclipse.papyrus.uml.diagram.activity.providers.UMLViewProvider.createNode(UMLViewProvider.java:322)
at org.eclipse.gmf.runtime.diagram.core.services.view.CreateNodeViewOperation.execute(CreateNodeViewOperation.java:67)
at org.eclipse.gmf.runtime.common.core.service.ExecutionStrategy$1.execute(ExecutionStrategy.java:70)
at org.eclipse.gmf.runtime.common.core.service.Service.execute(Service.java:651)
at org.eclipse.gmf.runtime.diagram.core.services.ViewService.execute(ViewService.java:184)
at org.eclipse.gmf.runtime.diagram.core.services.ViewService.createNode(ViewService.java:499)
at org.eclipse.gmf.runtime.diagram.core.services.ViewService.createView(ViewService.java:265)
at org.eclipse.papyrus.uml.diagram.common.commands.CreateBehavioredClassifierDiagramCommand.createBehaviorView(CreateBehavioredClassifierDiagramCommand.java:98)
at org.eclipse.papyrus.uml.diagram.common.commands.CreateBehavioredClassifierDiagramCommand.initializeDiagram(CreateBehavioredClassifierDiagramCommand.java:48)
at org.eclipse.papyrus.uml.diagram.common.commands.CreateBehavioredClassifierDiagramCommand.createDiagram(CreateBehavioredClassifierDiagramCommand.java:117)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler$2.doExecuteWithResult(AbstractPapyrusGmfCreateDiagramCommandHandler.java:318)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:134)
at org.eclipse.papyrus.commands.wrappers.GMFtoEMFCommandWrapper.execute(GMFtoEMFCommandWrapper.java:118)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
at org.eclipse.papyrus.commands.CheckedOperationHistory.execute(CheckedOperationHistory.java:182)
at org.eclipse.papyrus.commands.NotifyingWorkspaceCommandStack.doExecute(NotifyingWorkspaceCommandStack.java:252)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler.runAsTransaction(AbstractPapyrusGmfCreateDiagramCommandHandler.java:125)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler$1.doExecute(AbstractPapyrusGmfCreateDiagramCommandHandler.java:279)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler.createDiagram(AbstractPapyrusGmfCreateDiagramCommandHandler.java:282)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.initDiagrams(CreateModelWizard.java:440)
at org.eclipse.papyrus.uml.diagram.wizards.InitModelWizard.initDiagrams(InitModelWizard.java:192)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.initDiagramModel(CreateModelWizard.java:398)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.createAndOpenPapyrusModel(CreateModelWizard.java:179)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.performFinish(CreateModelWizard.java:156)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:492)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1021)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:915)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Are you already working on this issue? When will there be a Papyrus Version with a working Activity Diagram?
Benjamin
FUDForum. Page generated in 0.05455 seconds
