Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EDAPT] Migration validation issue
[EDAPT] Migration validation issue [message #892746] Fri, 29 June 2012 09:19 Go to next message
I'm trying to follow the tutorial using Library example.
I successfully create my migrator with the library.history file. The problem appears at the end of the migration, during the check of the conformance. I get the following validation error :
The 'validContainment' constraint is violated on 'Instance of type "Writer"'
I had a look to this validation rule and it appears that there might be a problem with the instance.getReferences not return all the references.
Here myLibrary in version 1.0.0
http://uploadpad.com/files/libraryExample.png
Tolkien Writer instance is referenced in 2 books (no containment references) and in library (containment reference). However in the validContainment rule, the call to instance.getReferences() only returns the two books references and as Writer is not the root instance, it fails.
I don't think the changes made in the migration are involved in this, I just changed the Book feature name "title" to "bookTitle".
If a someone have encounter the same issue and solve it, I'll be happy to know how ! If it's bug I'll be glad to fill a bugzilla.
Romain.
Re: [EDAPT] Migration validation issue [message #892886 is a reply to message #892746] Sun, 01 July 2012 08:15 Go to previous messageGo to next message
Hi Romain,
can you please upload or send me the files. Then I can take a look at
your problem.
Markus
Am 29.06.2012 15:19, schrieb Romain Bioteau:
> "Writer"'
> Thanks
> Romain.
Re: [EDAPT] Migration validation issue [message #893003 is a reply to message #892746] Mon, 02 July 2012 05:05 Go to previous messageGo to next message
Hello Markus,
I attached, two files :
My.extlibrary is the EXTLibrary instance I want to migrate which is conform to the default EXTLibrary example ecore in Eclipse.
The zip file contains the new target model with .history file and new generated projects. The only I've made in the new ecore is changing the feature Book::title to Book:bookTitle.
Thanks to have look to this.
Romain
Re: [EDAPT] Migration validation issue [message #893124 is a reply to message #893003] Mon, 02 July 2012 14:00 Go to previous messageGo to next message
Hi Romain,
I just took a look at your upload. The reference Library.writers is
derived and thereby is not converted to the migration structure. As a
consequence, the containment constraint naturally fails after migration.
You made the reference derived, since you are using feature maps.
Unfortunately, at the moment, feature maps are not supported by Edapt.
However, if you really need support for feature maps, I may be able to
implement it. For your example, this does not seem to be too difficult.
However, I have not yet looked at all the possibilities that feature
maps offer. If you need feature maps, please create a CR and assign it
to my email address.
Markus
Am 02.07.2012 11:05, schrieb Romain Bioteau:
> Hello Markus,
> Romain
Re: [EDAPT] Migration validation issue [message #893198 is a reply to message #893124] Tue, 03 July 2012 03:35 Go to previous messageGo to next message
Hello Markus,
thank you very much.
Indeed I doesn't need feature maps or derived references (for now at least). I just took the EXTLibrary example randomly to try Edapt.
In my real use case we doesn't use those, so it should be OK I guess.
Thanks again for the time spent on this.
Romain
[EDAPT] Restore model to previous versions [message #973265 is a reply to message #893124] Tue, 06 November 2012 02:33 Go to previous messageGo to next message
I have a problem when I'm undoing the changes for metamodels in Edapt.
Initially I made changes and models are migrated successfully. But when I undo the metamodel changes to the previous release, I'm unable to restore the models(undo the models back) to the previous version. Is it right that we undo changes to the metamodel, release and then migrate models? When I did this way it is displaying "no migrator registered for model with that namespace".
Please anyone let me know if there is a possibility of restoring the model to the previous model so that it conforms to the previous version.
Thanks a lot,
Lucky
Re: [EDAPT] Migration validation issue [message #1695967 is a reply to message #893124] Wed, 20 May 2015 11:40 Go to previous messageGo to next message
Edapt is exactly the framework I need to migrate my model. Unfortunately we use FeatureMap. I read in your last message that it was not supported. I would like to know if it is planned for a future release ?
Helene.
Re: [EDAPT] Migration validation issue [message #1696026 is a reply to message #1695967] Thu, 21 May 2015 05:09 Go to previous message
Hi Helene,
there are currently no plans to implement this. Are you interested in
sponsoring this development?
Best regards
Jonas
Am 20.05.2015 um 17:40 schrieb Helene Molliere:
> Hello,
> Helene.
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Previous Topic:[Edapt] Customize load options
Next Topic: [EMFStore] Detecting changes of operations
Current Time: Wed Jul 23 03:11:28 EDT 2025
Powered by FUDForum. Page generated in 0.29358 seconds
