Home » Modeling » Papyrus » Problems with Papyrus 0.9.0
Problems with Papyrus 0.9.0 [message #876272] Thu, 24 May 2012 05:34 Go to next message
I tried different Versions (M6 and RC1) of Papyrus. In both Versions there is a problem with Activity Diagrams. In M6 I was not able to connect nodes with control flow, e.g. Opaque Actions with other Opaque Actions. In RC1 I cannot even create an Activity Diagram via the Papyrus Model Wizard. It creates a model.di file but I cannot open this file (I guess because the other files are not generated).
The stacktrace is:
at org.eclipse.papyrus.infra.core.utils.ServiceUtilsForActionHandlers.getServiceRegistry(ServiceUtilsForActionHandlers.java:70)
at org.eclipse.papyrus.infra.core.utils.ServiceUtilsForActionHandlers.getTransactionalEditingDomain(ServiceUtilsForActionHandlers.java:88)
at org.eclipse.papyrus.infra.emf.utils.EMFHelper.resolveEditingDomain(EMFHelper.java:190)
at org.eclipse.papyrus.uml.diagram.common.helper.PreferenceInitializerForElementHelper.initBackgroundFromPrefs(PreferenceInitializerForElementHelper.java:102)
at org.eclipse.papyrus.uml.diagram.activity.providers.UMLViewProvider.createActivity_2001(UMLViewProvider.java:547)
at org.eclipse.papyrus.uml.diagram.activity.providers.UMLViewProvider.createNode(UMLViewProvider.java:322)
at org.eclipse.gmf.runtime.diagram.core.services.view.CreateNodeViewOperation.execute(CreateNodeViewOperation.java:67)
at org.eclipse.gmf.runtime.common.core.service.ExecutionStrategy$1.execute(ExecutionStrategy.java:70)
at org.eclipse.gmf.runtime.common.core.service.Service.execute(Service.java:651)
at org.eclipse.gmf.runtime.diagram.core.services.ViewService.execute(ViewService.java:184)
at org.eclipse.gmf.runtime.diagram.core.services.ViewService.createNode(ViewService.java:499)
at org.eclipse.gmf.runtime.diagram.core.services.ViewService.createView(ViewService.java:265)
at org.eclipse.papyrus.uml.diagram.common.commands.CreateBehavioredClassifierDiagramCommand.createBehaviorView(CreateBehavioredClassifierDiagramCommand.java:98)
at org.eclipse.papyrus.uml.diagram.common.commands.CreateBehavioredClassifierDiagramCommand.initializeDiagram(CreateBehavioredClassifierDiagramCommand.java:48)
at org.eclipse.papyrus.uml.diagram.common.commands.CreateBehavioredClassifierDiagramCommand.createDiagram(CreateBehavioredClassifierDiagramCommand.java:117)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler$2.doExecuteWithResult(AbstractPapyrusGmfCreateDiagramCommandHandler.java:318)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:134)
at org.eclipse.papyrus.commands.wrappers.GMFtoEMFCommandWrapper.execute(GMFtoEMFCommandWrapper.java:118)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
at org.eclipse.papyrus.commands.CheckedOperationHistory.execute(CheckedOperationHistory.java:182)
at org.eclipse.papyrus.commands.NotifyingWorkspaceCommandStack.doExecute(NotifyingWorkspaceCommandStack.java:252)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler.runAsTransaction(AbstractPapyrusGmfCreateDiagramCommandHandler.java:125)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler$1.doExecute(AbstractPapyrusGmfCreateDiagramCommandHandler.java:279)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler.createDiagram(AbstractPapyrusGmfCreateDiagramCommandHandler.java:282)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.initDiagrams(CreateModelWizard.java:440)
at org.eclipse.papyrus.uml.diagram.wizards.InitModelWizard.initDiagrams(InitModelWizard.java:192)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.initDiagramModel(CreateModelWizard.java:398)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.createAndOpenPapyrusModel(CreateModelWizard.java:179)
at org.eclipse.papyrus.uml.diagram.wizards.CreateModelWizard.performFinish(CreateModelWizard.java:156)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:492)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1021)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:915)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Are you already working on this issue? When will there be a Papyrus Version with a working Activity Diagram?
Benjamin
Re: Problems with Papyrus 0.9.0 [message #891927 is a reply to message #876272] Tue, 26 June 2012 11:35 Go to previous messageGo to next message
I also cannot create simple constructs in Papyrus 0.9 on Juno build 20120606-2254/Windows Vista. I cannot even get a control flow connector to link to an initial node/opaque action/activity final. Is there something i'm missing here?
Ronan
Re: Problems with Papyrus 0.9.0 [Activity Diagrams] [message #892744 is a reply to message #876272] Fri, 29 June 2012 09:16 Go to previous messageGo to next message
I have figured this out now. Papyrus doesn't always create Opaque Actions or Initial/Final elements correctly. Sometimes they have no owner defined. This means they cannot have Control Flow elements defined between them. An icon with a red stripe appears on such "orphan" elements.
This always seems to occur when one uses the Palette to place elements in the Activity. The elements get created correctly when I use the Model Explorer.
Very annoying bug. I'll file it to bugzilla.
Ronan
Re: Problems with Papyrus 0.9.0 [Activity Diagrams] [message #892753 is a reply to message #892744] Fri, 29 June 2012 09:33 Go to previous messageGo to next message
Hello Ronan,
I think this has been fixed in the late revisions of Juno (Such as RC2 or RC3). This should work fine on the final version (Which has been released two days ago).
Camille
Re: Problems with Papyrus 0.9.0 [Activity Diagrams] [message #892757 is a reply to message #892753] Fri, 29 June 2012 09:51 Go to previous message
Okay great! This works fine now on Version: Juno Release, Build id: 20120620-1657. My models were created with the Papyrus build just before that one so I just deleted the elements and recreated them.
Ronan
Previous Topic:how can we show properties of a stereotype in a diagram??
Next Topic:How to programmatically select an element in Papyrus Model Explorer
Current Time: Thu Jul 24 23:13:24 EDT 2025
Powered by FUDForum. Page generated in 0.09470 seconds
