Home » Archived » BIRT » library with joint data set not setting parameter
library with joint data set not setting parameter [message #892294] Wed, 27 June 2012 12:05 Go to next message
I am having an issue where the parameter in a joint data set within a library is not being set from the outer table.
I have 2 tables one nested inside of the first. The first table is bound to a dataset with an id column and the nested table is bound to a joint data set. I bound the 1 parameter to the id of the first table, but it always uses the default value.
If I move the tables/data sets to a blank report it correctly sets the parameter value in the nested table.
Is this a known issue? If so is there a workaround for it?
Thank you
Re: library with joint data set not setting parameter [message #892585 is a reply to message #892294] Thu, 28 June 2012 11:38 Go to previous messageGo to next message
I seem to remember there was an issue with this with earlier versions.
What version are you using?
Jason
> Thank you
Re: library with joint data set not setting parameter [message #892589 is a reply to message #892294] Thu, 28 June 2012 11:38 Go to previous messageGo to next message
Jason
> Thank you
Re: library with joint data set not setting parameter [message #892785 is a reply to message #892589] Fri, 29 June 2012 12:25 Go to previous messageGo to next message
I am using version 3.7
Eclipse BIRT Designer Version 3.7.2.v20120213 Build <3.7.2.v20120214-1408
Re: library with joint data set not setting parameter [message #892806 is a reply to message #892785] Fri, 29 June 2012 14:58 Go to previous message
Can you open a bugzilla entry for this?
Jason
> Thanks
Previous Topic:Bug on the two dimensional with depth chart?
Next Topic:pdf generator's source code
Current Time: Wed Jul 23 06:45:56 EDT 2025
Powered by FUDForum. Page generated in 0.04748 seconds
