Home » Modeling » TMF (Xtext) » generating classes for evaluating Xbase expressions in Xtext?
generating classes for evaluating Xbase expressions in Xtext? [message #892502] Thu, 28 June 2012 09:25 Go to next message
I am trying to design a little DSL for checking constraints on variables. My grammar at the moment looks like this:
 Start:
    	varDeclarations += XVariableDeclaration*
    	rules+=Constraint*;
    Constraint:
    	{Constraint}
    	'FOR' 'PAYLOAD' payload=PAYLOAD 'ELEMENT' element=ID 'CONSTRAINED BY' constraint=XExpression;
    PAYLOAD:
    	"SimulationSessionEvents"
    	|"stacons"
    	|"any"
I want to generate instances of a class containing just one method that takes as input a value, maps it to the only variable contained in the constraint(which is also the only variable declared), and checks if the constraint is satisfied.
These instances will then be used by another class, which passes a value through each instance, checking if it's constraint is satisfied.
As I see it I have 2 options:
1. Explicitly generate code for a constraint class, in which case I can just use `XBaseCompiler` to generate the expression evaluation code. However I would then have to load these classes somehow, which seems inelegant, if there is a way to create in memory objects directly.
2. Use the `ModelInferrer` to directly generate in memory objects which can be passed to the other class, so no class loading is required. I am not sure how to generate the xbase expression evaluation code in this case.
After reading all the xtext documentation/tutorials, and playing around with the examples, I am left with the following questions:
Which is the 'best' approach in terms of scalabilty (I may later want to extend the grammar, and/or the functions of he generated classes)?
How exactly would I go about things if I were to follow the ModelInferrer approach?
Is there any other way of doing this?
Any help would be much appreciated
Re: generating classes for evaluating Xbase expressions in Xtext? [message #892638 is a reply to message #892502] Thu, 28 June 2012 18:09 Go to previous message
Quoted from SO:
The best approach is to use the model inferer to create the Java
representation of your DSL elements. The expression is usually assigned
by means of the JvmTypeBuilder#setBody. Have a look at the domain model
example where you'll find the the assignment to the operation body:
members += f.toMethod(f.name, f.type) [
for (p : f.params) {
parameters += p.toParameter(p.name, p.parameterType)
body = f.body
Another option is to create the code manually:
body = [
append(varName).append(' = new ').append(typeName).append('();')
The inferer approach allows for powerful Eclipse integration since type
hierarchy, call hierarchy or go-to-declaration will all honor the
derived Java things.
Sebastian
Am 28.06.12 15:25, schrieb Marcus Mathioudakis:
> Start:
> rules+=Constraint*;
> Constraint:
> {Constraint}
> PAYLOAD:
> |"stacons"
> |"any"
> extend the grammar, and/or the functions of he generated classes)? How
> approach? Is there any other way of doing this?
Previous Topic:Context based expressions
Next Topic:cannot run Junit plugin tests anymore
Current Time: Sat Jul 26 18:53:53 EDT 2025
Powered by FUDForum. Page generated in 0.07877 seconds
