Home » Newcomers » Newcomers » Lock the Toolbars (Unlock) impossible with eclipse juno
icon9.gif  Lock the Toolbars (Unlock) impossible with eclipse juno [message #892285] Wed, 27 June 2012 11:26 Go to next message
I have just installed the latest release of Eclipse (Juno) and I am afraid because I can't unlock the toolbars with "Quick Access" or any other options ... In Eclipse Indigo this option works fine but this option doesn't work in Juno.
When you type "toolbars" in the "Quick Access" field, why the option "Lock the Toolbars" in this field doesn't work ???
Is it normal ?
I didn't find an option to do that.
Is it a bug ? regression ?
How can I ordered my toolbars ?
Please could you help me to solve this issue ?
Thank you in advance for your help.
[Updated on: Wed, 27 June 2012 13:21] by Moderator
Re: Lock the Toolbars (Unlock) impossible with eclipse juno [message #892360 is a reply to message #892285] Wed, 27 June 2012 17:26 Go to previous messageGo to next message
Someone has the same problem ??
What is mentioned on the help page in "Rearranging the main toolbar" doesn't work.
Why ? Is it normal ?
Thank you for your help.
Re: Lock the Toolbars (Unlock) impossible with eclipse juno [message #892385 is a reply to message #892360] Wed, 27 June 2012 20:13 Go to previous messageGo to next message
> doesn't work.
You should be able to change the menu using the Customize Perspective
action. You can access the action using either Quick Access or through
Window->Customize Perspective.
The lock/unlock feature doesn't appear to be supported by the new framework.
Re: Lock the Toolbars (Unlock) impossible with eclipse juno [message #892408 is a reply to message #892385] Thu, 28 June 2012 03:17 Go to previous messageGo to next message
Why The lock/unlock feature doesn't appear to be supported by the new framework ??
Where does it mentioned that this feature are not supported by the new framework ??
Re: Lock the Toolbars (Unlock) impossible with eclipse juno [message #892569 is a reply to message #892408] Thu, 28 June 2012 12:02 Go to previous messageGo to next message
Moving eclipse toolbars in the main toolbar is bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=340695
It's not that the toolbar is locked, the items are not yet draggable.
PW
Re: Lock the Toolbars (Unlock) impossible with eclipse juno [message #892784 is a reply to message #892360] Fri, 29 June 2012 12:23 Go to previous message
I just installed Eclipse Juno and have the same problem.
Previous Topic:Removing old topics????
Next Topic:SVNKIT logging enabled not showing expected logs
Current Time: Fri Jul 25 19:22:15 EDT 2025
Powered by FUDForum. Page generated in 0.09311 seconds
