Home » Modeling » EMF » my EMF model generated tests...
my EMF model generated tests... [message #892340] Wed, 27 June 2012 15:37 Go to next message
I am trying to finally get some Junit tests running on my EMF model. The EMF model was created and code was generated for an RCP application. The model plugin itself "should" be standalone - right?
Well, my question is this: I generated the test code from the .genmodel. It created a project with appropriately stubbed out code. I try to run one of the resulting XXXTest.java files as Run As->Junit test .... and it fails to be able to load the class.
Is there a tutorial or information out there on doing this? I am just trying to test the model only - just create an object, or series of objects in my model, and verify that it is then providing the data I expect. This way we can create some automated tests that don't rely on the GUI display, and can test other aspects of the product.
I hope someone out there can help!
-Sharon
Re: my EMF model generated tests... [message #892397 is a reply to message #892340] Thu, 28 June 2012 02:14 Go to previous messageGo to next message
Sharon,
Comments below.
On 27/06/2012 9:37 PM, Sharon Snyder wrote:
This only affects the generated editor; the model and edit bundles as
well as the EMF runtime and EMF Edit always function stand alone.
I tried it locally just now, and that worked for me. By "the class"
which class do you mean?
> expect.
Can you run the XyzExample as a Java application or does that have class
loading problems too?
Did you modify the classpath of your model or tests?
> -Sharon
Re: my EMF model generated tests... [message #892505 is a reply to message #892397] Thu, 28 June 2012 09:34 Go to previous message
Hi Ed,
I'm not sure what I changed....but with your hint I got it working. I basically removed the whole project, had the genmodel recreate it and voila! It worked!
I think it had something to do with the pom file associated with it at the time. It was probably changed early on when we were creating our product build (tycho/maven) and we never looked at the .tests projects until now!
Thanks!!
Sharon
Previous Topic:[CDO] Installing on E4.2
Next Topic:Collecting XMI files backing an entire EMF Model
Current Time: Fri Sep 19 02:19:31 EDT 2025
Powered by FUDForum. Page generated in 0.03071 seconds
