Beginner Question [message #892323] |
Wed, 27 June 2012 13:45  |
UPDATE: I had to remove all links to be able to post, I replaced them with ...
I just started learning about buckminster, and I am encountering an issue which I believe should be pretty basic.
I have setup 3 different eclipse projects
A feature: com.ixiasoft.test.buckminster.feature
A plugin : com.ixiasoft.test.buckminster (required from the feature)
A standard Java Project: com.ixiasoft.utils (to illustrate a source library that will be built as a jar for example.)
I have added a buckminster.cspec file to the com.ixiasoft.utils project so that it can be resolved.
My cquery and rmap are able to resolve the feature/plugin but the "library" is not found. " ERROR [0000] : No suitable provider for component com.ixiasoft.utils:osgi.bundle was found in searchPath resource"
Now I am pretty sure I did something funky, but I can't seem to figure it out.
Here are my cquery, rmap, and cspec files I am using. If anyone can point me in the right direction it would be great.
Thanks for all the help.
<cq:componentQuery xmlns:cq="...//www.eclipse.org/buckminster/CQuery-1.0" resourceMap="file:/C:/Users/periardy/buckminster/buckminster/com.ixiasoft.eclipse.dita-cms.rmap">
<cq:rootRequest name="com.ixiasoft.eclipse.test.buckminster.feature" componentType="eclipse.feature"/>
</cq:componentQuery>
<!-- RMAP -->
<rmap
<!-- Place your RMAP content here -->
<!-- Is this really required? As this is the same as the default one? -->
<searchPath name="resource">
<provider
readerType="svn"
componentTypes="osgi.bundle,buckminster"
source="true">
<uri
format="{0}/trunk/{1}?moduleAfterTag&moduleAfterBranch">
<bc:propertyRef key="svn.root"/>
<bc:propertyRef key="buckminster.component"/>
</uri>
</provider>
</searchPath>
<searchPath name="default">
<provider
readerType="svn"
componentTypes="eclipse.feature,osgi.bundle,buckminster"
source="true">
<uri
</uri>
</provider>
</searchPath>
<!-- This works with the test feature -->
<locator searchPathRef="default" pattern="^com\.ixiasoft\.eclipse\.test\.buckminster" />
<!-- The standard eclipse project com.ixiasoft.utils is never found from SVN, why? -->
<!-- When the com.ixiasoft.utils project has been previously checked out, in the workspace, then it works; why? -->
<locator searchPathRef="resource" pattern="^com\.ixiasoft\.utils.*" />
<property key="svn.root" value="...svn.foo.local/svn/dita-cms" />
</rmap>
<!-- cspec in the com.ixiasoft.utils project -->
<cs:cspec xmlns:cs="...//www.eclipse.org/buckminster/CSpec-1.0" name="com.ixiasoft.utils" componentType="osgi.bundle"/>
Re: Beginner Question [message #892390 is a reply to message #892376] |
Wed, 27 June 2012 22:53  |
I seem to have found it, it was due to a difference in the naming of the project itself versus the svn naming. I suppose my locator regex was too constrained to make it work. I am still playing with it to see if I can make a dependency without renaming a legacy project.
FUDForum. Page generated in 0.05469 seconds
