Home » Archived » Buckminster » strange problem with Buckminster Wizard for existing Xtext language projects
strange problem with Buckminster Wizard for existing Xtext language projects [message #892217] |
Wed, 27 June 2012 08:30  |
I started using this wonderful wizard which comes with Xtext 2.3.0 for
building my Xtext language with Buckminster and Jenkins
now I have a strange problem:
The jenkins commands (based on the commands.txt generated by the wizard) are
resolve releng/it.xsemantics.buckminster/projects-platform.cquery
resolve releng/it.xsemantics.buckminster/project.cquery
clean
build
perform -D target.os=* -D target.ws=* -D target.arch=*
it.xsemantics.site#buckminster.clean
it.xsemantics.site#site.p2.zip
and some junit tests
when I run the Jenkins job in a clean workspace (e.g., the first time I
run the job or after a wipe out of the workspace), the target platform
is resolved, but then project.cquery resolve fails with some errors due
to source bundles which are not found, e.g., (only some of the errors
are shown):
ERROR [0019] : No suitable provider for component
org.eclipse.xtext.junit4.source:osgi.bundle/[2.3.0.v201206120633,2.3.0.v201206120633]
was found in resourceMap
file:/usr/share/tomcat6/.jenkins/workspace/xsemantics-buckminster-gerrit/releng/it.xsemantics.buckminster/project.rmap
ERROR [0019] : Unable to find a searchPath for
org.eclipse.xtext.junit.source:osgi.bundle/[2.3.0.v201206120633,2.3.0.v201206120633]
ERROR [0044] : No suitable provider for component
org.hamcrest.integration.source:osgi.bundle/[1.1.0.v20090501071000,1.1.0.v20090501071000]
ERROR [0044] : Unable to find a searchPath for
If I then run the job again (without wiping the workspace) then
everything goes fine...
the project-platform.cquery (generated by the wizard) has an advisor
node to skip sources
<cq:advisorNode namePattern="^.*\.source$" skipComponent="true"/>
so why should it want to resolve source bundles?
can it be due to the fact that in my repository I also insert the source
feature (but only of my own plugins)?
I would also like to track down the issue... but I don't know how to
interpret INFO such as
org.hamcrest.library.source:osgi.bundle/[1.1.0.v20090501071000,1.1.0.v20090501071000]
INFO: TAG-ID 0019 = Query for it.xsemantics.site:eclipse.feature, path:
it.xsemantics.site:eclipse.feature$1.0.0.qualifier ->
it.xsemantics.tests.feature:eclipse.feature$1.0.100.qualifier ->
org.eclipse.xtext.sdk:eclipse.feature$2.3.0.v201206120633
TAG-ID 0022 = Query for it.xsemantics.site:eclipse.feature, path:
it.xsemantics.example.expressions.tests:osgi.bundle$1.0.100.qualifier ->
it.xsemantics.example.expressions:osgi.bundle$1.0.100.qualifier
TAG-ID 0044 = Query for it.xsemantics.site:eclipse.feature, path:
org.eclipse.swtbot:eclipse.feature$2.0.5.20111003_1754-3676ac8-dev-e36
can I understand from this who's trying to import source bundles?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: strange problem with Buckminster Wizard for existing Xtext language projects [message #892260 is a reply to message #892229] |
Wed, 27 June 2012 10:11   |
On 06/27/2012 02:58 PM, Dennis Huebner wrote:
> Hi Lorenzo!
Hi Dennis! Thanks for the quick reply!
> Missing Xtext sources come it.xsemantics.tests.feature:eclipse.feature
> (you should not include Xtext SDK in your feature).
I added xtext sdk to the tests feature because I run swtbot tests that
test that I can create a project with the wizard for some DSL examples,
and also that I can create in the workspace some examples projects
(similar to the examples projects of Xtext itself)... so I thought I'd
need xtext sdk in the test feature to perform swtbot tests, am I right?
> And hamcrest stuff comes definitely from the swtbot feature:
> http://git.eclipse.org/c/swtbot/org.eclipse.swtbot.git/tree/org.eclipse.swtbot/feature.xml
> To track an error, you should look at the error id e.g. in hamcrest
> case its 0044:
> So if you check the trace below you can see that org.eclipse.swtbot
> requested it
OK, thanks for the clarification :)
please see also my other answer
cheers
Lorenzo
Re: strange problem with Buckminster Wizard for existing Xtext language projects [message #892261 is a reply to message #892252] |
Hi again :)
On 06/27/2012 03:50 PM, Dennis Huebner wrote:
> Quote:
> The advisor node is in the target platform cquery. But your source
> dependencies comes from the project cquery so the node is not active.
> Quote:
>> source feature (but only of my own plugins)?
> Your project dependencies require this sources. So it's better to add
> them to your target platform.
so I did some experiments before you wrote this other message, and I
modified projects-platform.cquery as follows:
<cq:componentQuery
xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap="projects-platform.rmap">
<cq:rootRequest name="it.xsemantics.buckminster"
componentType="buckminster"/>
<cq:property key="buckminster.download.source" value="true"/>
<cq:property key="target.arch" value="*"/>
<cq:property key="target.os" value="*"/>
<cq:property key="target.ws" value="*"/>
</cq:componentQuery>
thus, I removed the advisor node, and request explicit download of
sources...
things get better now: if I wipe the workspace before the build the
sources are downloaded... but one problem remains: I get errors only for
this source bundle
INFO: resolve 'releng/it.xsemantics.buckminster/project.cquery'
WARNING [0012] : Component request
org.apache.log4j:osgi.bundle/[1.2.13.v200903072027,1.2.13.v200903072027]
is in conflict with request org.apache.log4j:osgi.bundle/1.2.15
ERROR [0012] : No suitable provider for component
org.apache.log4j.source:osgi.bundle/[1.2.13.v200903072027,1.2.13.v200903072027]
ERROR [0012] : Unable to find a searchPath for
org.apache.log4j.source:osgi.bundle/[1.2.15.v201012070815,1.2.15.v201012070815]
org.apache.log4j:osgi.bundle/[1.2.15.v201012070815,1.2.15.v201012070815]
INFO: TAG-ID 0012 = Query for it.xsemantics.site:eclipse.feature, path:
Now... this log4j plugin always troubled me (for instance, in my eclipse
installation I usually end up having both 1.2.13 and 1.2.15 and if I
don't remove manually 1.2.13 then xtend2 editor stops working...)
now it looks like it cannot get the source correctly (again, if I run
the job again, without wiping out the workspace, everything goes on
without errors, only warnings).
can I deal with this conflict somehow?
> I've added the "skip sources" advisor node to minimize the TP download
> size, so you can just remove or edit it. If you would like to include
> the swtbot sources in your project's repository, add following line to
> your buckminster.scpec (and edit or remove the advisor node above, of
> cause) :
> <cs:dependency name="org.eclipse.swtbot" componentType="eclipse.feature"/>
actually I wouldn't need the swtbot sources... but somehow this is
requested by something in my tests feature...
I understand that xtext sources come from xtext.sdk feature... but
there's no sdk feature for swtbot in my tests feature... or probably
it's org.eclipse.swtbot feature itself which wants sources...
thanks in advance
Lorenzo
Re: strange problem with Buckminster Wizard for existing Xtext language projects [message #892460 is a reply to message #892261] |
Thu, 28 June 2012 06:03   |
> this source bundle
>> cause) :
I think I solved this problem (but any feedback would be welcome :)
of course I need xtext sources since the test feature includes xtext.sdk
which seems to require sources
as for log4j it looks like the orbit update site provides the sources
for log4j 1.2.15, but not for 1.2.13 (for this, only the binaries) (!)
see for instance
http://download.eclipse.org/tools/orbit/downloads/drops/R20120526062928/
fortunately, the sources for log4j are not strictly required by swtbot,
thus I can modify the projects-platform.cquery as follows
<cq:componentQuery
<cq:advisorNode namePattern="^org\.apache.*\.source$"
i.e., instruct to download also the sources (required by xtext.sdk), but
excluding the sources for org.apache.* bundles with the advisor node.
This, however would trouble project.cquery, since the target platform
would be resolved, but then, when resolving the projects the sources for
log4j would still be required (I don't know how, actually), thus, I need
to modify project.cquery with a similar advisor node
<cq:componentQuery
resourceMap="project.rmap">
<cq:rootRequest name="it.xsemantics.site"
this solves my problems (the Jenkins job works both from a wiped
workspace and from an existing workspace)
but I'd like to know whether the solution makes sense :)
thanks in advance
Lorenzo
Re: strange problem with Buckminster Wizard for existing Xtext language projects [message #892470 is a reply to message #892460] |
Thu, 28 June 2012 06:42   |
You probably just need xtext.junit or xtext.junit4 bundles from the xtext.sdk and not the whole feature.
It don't require it at all I think, see http://git.eclipse.org/c/swtbot/org.eclipse.swtbot.git/tree/org.eclipse.swtbot/feature.xml
I think that buckminster.download.source value="true" cause that log4j sources became required.
IMHO it is better to remove buckminster.download.source value="true" again, and instead add only the stuff you really need in your buckminster.cspec
<cs:dependency name="org.eclipse.platform" componentType="eclipse.feature"/>
<cs:dependency name="org.eclipse.xtext.sdk" componentType="eclipse.feature"/>
Or even better add the dependencies to the bundles not to the features (where possible). I.e. if you need a bundle X you don't have to import the whole feature with lots of other bundles(and probably extra dependencies) in it.
The task of the platform cquery file, is to materialize the platform your project can build on. So after it is resolved any 3rd party artifacts should be missing or requested by the project cquery.
Dennis.
Re: strange problem with Buckminster Wizard for existing Xtext language projects [message #892533 is a reply to message #892470] |
Thu, 28 June 2012 10:38   |
On 06/28/2012 12:42 PM, Dennis Huebner wrote:
> Quote:
>> xtext.sdk which seems to require sources
I'll try this also even because I now have another problem (see below)
> Quote:
I had solved this with the specific advisor node but...
> Quote:
>> but excluding the sources for org.apache.* bundles with the advisor node.
> buckminster.cspec
I already had this but the sources, from what I understand, are required
at the moment that buckminster imports my test feature which includes
xtext.sdk if I understand correctly...
> Quote:
>> for log4j would still be required (I don't know how, actually), thus,
>> I need to modify project.cquery with a similar advisor node
I see
now after switching to xtext 2.3 Juno released today, I updated the rmap
in order to use juno update site and xtext composite release update site
and the problem with sources looks solved, but now I have problems when
building the site:
INFO: perform '-D' 'target.os=*' '-D' 'target.ws=*' '-D'
'target.arch=*' 'it.xsemantics.site#site.p2.zip'
CSpec org.eclipse.equinox.common:osgi.bundle$3.6.100.v20120522-1841 has
no action, group, or local artifact named java.binaries
that's why I want to get rid of downloading sources
but can the error above be due also to the fact that I'm still using
buckminster 3.7?
I'll now try to get rid of sources anyway :)
thanks again
cheers
Lorenzo
Re: strange problem with Buckminster Wizard for existing Xtext language projects [message #892808 is a reply to message #892470] |
Fri, 29 June 2012 15:16  |
> Quote:
> Quote:
> Quote:
> buckminster.cspec
Hi Dennis
I managed to remove xtext.sdk from the test feature and now I don't need
sources anymore :)
thanks a lot!
cheers
Lorenzo
Current Time: Sat Jul 26 12:52:14 EDT 2025
Powered by FUDForum. Page generated in 0.09019 seconds
