Home » Language IDEs » Java Development Tools (JDT) » creating xml schema from the above java code(Please anyone help me in creating xml schema from the above java code)
creating xml schema from the above java code [message #892195] Wed, 27 June 2012 07:31
import java.io.BufferedWriter;
import java.io.FileWriter;
import java.io.IOException;
import java.util.Random;
* @author mh
* @since 13.01.12
public class TestDataGenerator1 {
private static int NODES = 75 * 1000; // * 1000;
private static final int RELS_PER_NODE = 10;
private static final String[] TYPES = {"ONE","TWO","THREE","FOUR","FIVE","SIX","SEVEN","EIGHT","NINE","TEN"};
public static void main(String...args) throws IOException {
Random rnd = new Random();
long relCount=0, time = System.currentTimeMillis();
BufferedWriter nodeFile = new BufferedWriter(new FileWriter("D:\\nodes.xml"));
nodeFile.write("Node\tRels\tProperty\n");
BufferedWriter relFile = new BufferedWriter(new FileWriter("rels.xml"));
relFile.write("Start\tEnde\tType\tProperty\n");
for (int node = 0; node < NODES; node++) {
final int rels = rnd.nextInt(RELS_PER_NODE);
nodeFile.write(node+"\t"+rels+"\tTEST\n");
for (int rel = rels; rel >= 0; rel--) {
relCount++;
final int node1 = rnd.nextInt(NODES);
final int node2 = rnd.nextInt(NODES);
relFile.write(node1 + "\t" + node2 + "\t" + TYPES[rel] + "\t" + "Property"+ "\n");
nodeFile.close();
relFile.close();
System.out.println("Creating "+NODES+" and "+relCount+" Relationships took "+((System.currentTimeMillis()-time)/1000)+" seconds.");
Previous Topic:How to fix java.net.UnknownHostException error
Next Topic:Problem updating latest Android Development Tools...
Current Time: Mon Jul 21 00:37:36 EDT 2025
Powered by FUDForum. Page generated in 0.04165 seconds
