Spring Security OAuth2 not loading [message #892049] |
Tue, 26 June 2012 20:53  |
We are running Virgo 3.5.0.M03 with spring security oauth 2 version 1.0.0.M6d. It is failing to load the bundle because it cannot resolve an optional dependency to junit. Any help would be greatly appreciated.
Steve
[2012-06-26 17:30:14.378] ERROR fs-watcher org.eclipse.virgo.medic.eventlog.default HD0002E Hot deploy failed for file 'spring-security-oauth2-1.0.0.M6d.jar'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Dependency satisfaction failed
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:363)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:184)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:139)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:252)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeployerFileSystemListener.java:163)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeployerFileSystemListener.java:67)
at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:245)
at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:166)
at org.eclipse.virgo.kernel.deployer.hot.WatchTask.run(WatchTask.java:48)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'org.springframework.security.oauth' at version '1.0.0.M6d': Cannot resolve: org.springframework.security.oauth
Resolver report:
An Import-Package could not be resolved. Resolver error data <Import-Package: org.junit.internal; version="[4.8.2,5.0.0)">. Caused by missing constraint in bundle <org.springframework.security.oauth_1.0.0.M6d>
constraint: <Import-Package: org.junit.internal; version="[4.8.2,5.0.0)">
with attributes {optional=true}
at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.QuasiResolveStage.process(QuasiResolveStage.java:46)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:360)
FUDForum. Page generated in 0.09079 seconds
