Home » Archived » BIRT » 'Internal error' when opening PDF preview window
'Internal error' when opening PDF preview window [message #891884] Tue, 26 June 2012 08:35 Go to next message
For some time now I get an 'Internal error' message when the PDF preview window is opened for the second time.
Like this...
    open BIRT viewer in eclipse
    select PDF output
    select print
    close PDF preview
    close viewer
    open viewer
    select PDF output
    'Internal error occured'
I then have to close & restart eclipse.
Re: 'Internal error' when opening PDF preview window [message #891941 is a reply to message #891884] Tue, 26 June 2012 11:57 Go to previous messageGo to next message
What version are you using?
Jason
> Like this...
> select PDF output
> select print
> close PDF preview
> close viewer
> open viewer
> select PDF output
Re: 'Internal error' when opening PDF preview window [message #892064 is a reply to message #891941] Wed, 27 June 2012 00:42 Go to previous messageGo to next message
Eclipse Indigo SR1 20110916-0149
BIRT 3.7.2 20120213
Re: 'Internal error' when opening PDF preview window [message #892522 is a reply to message #892064] Thu, 28 June 2012 10:22 Go to previous message
Paul
I tried to reproduce this issue and I could not. Can you check the
workspace log in the .metadata directory to see if it shows anything?
Jason
> BIRT 3.7.2 20120213
Previous Topic:How to use charAt() in a highlight expression?
Next Topic:question on report design
Current Time: Wed Jul 23 12:45:08 EDT 2025
Powered by FUDForum. Page generated in 0.27967 seconds
