Home » Archived » BIRT » How to influence sorting rules in a group
How to influence sorting rules in a group [message #891504] Mon, 25 June 2012 02:14 Go to next message
I have a table which has a group on Country. The country names are in German and contain umlauts. So Austria is Österreich and comes after Zimbabwe in the report result. Ideally, it should appear between N and P.
How can I influence this? The data originates from SQL Server which does order correctly (Ö interpreted as Oe). After grouping by BIRT this ordering is lost.
Paul
Re: How to influence sorting rules in a group [message #891762 is a reply to message #891504] Mon, 25 June 2012 16:00 Go to previous messageGo to next message
Paul
Did you set the locale for the sort?
http://www.eclipse.org/birt/phoenix/project/notable2.6.php#jump_15
See attached example.
Jason
> ordering is lost.
> Thanks
> Paul
Re: How to influence sorting rules in a group [message #891763 is a reply to message #891504] Mon, 25 June 2012 16:00 Go to previous messageGo to next message
Paul
Jason
> ordering is lost.
> Thanks
> Paul
Re: How to influence sorting rules in a group [message #891764 is a reply to message #891504] Mon, 25 June 2012 16:00 Go to previous messageGo to next message
Paul
Jason
> ordering is lost.
> Thanks
> Paul
Re: How to influence sorting rules in a group [message #891881 is a reply to message #891764] Tue, 26 June 2012 08:28 Go to previous messageGo to next message
Jason
thanks for your help again!
No, I hadn't noticed the locale setting in sort. What I am actually doing is a group not a sort. The group seems to sort differently or do I apply a sort as well?
Paul
Re: How to influence sorting rules in a group [message #891940 is a reply to message #891881] Tue, 26 June 2012 11:56 Go to previous message
Paul,
Can you try to select the table and add a locale based sort on it? Also
you may want to try and use the sort tab in the group editor as well.
Jason
On 6/26/2012 8:28 AM, Paul Ramsden wrote:
> Jason
> Paul
Previous Topic:Best SWT emitter?
Next Topic:Custom Parameter Page in Run Time
Current Time: Sat Jul 26 03:43:38 EDT 2025
Powered by FUDForum. Page generated in 0.04754 seconds
