Home » Modeling » EMF » [EMF] [CDO] What is the proper way to commit EClass instance to CDO server?
[EMF] [CDO] What is the proper way to commit EClass instance to CDO server? [message #891644] Mon, 25 June 2012 08:03 Go to next message
I tried to create an EClass instance using org.eclipse.em.ecore.EcoreFactory.createEClass() and add it to the CDO server with the following code
//create configuration
CDONet4jSession session = configuration.openNet4jSession();
session.getPackageRegistry().putEPackage(EcorePackage.eINSTANCE);
CDOTransaction trans = session.openTransaction();
try {
	Resource resource = trans.getOrCreateResource("umlresource");
	EClass eObject = EcoreFactory.eINSTANCE.createEClass();
	eObject.setName("MyClass");
	resource.getContents().add(eObject);
	trans.commit();
finally {
	if (trans != null) {
		trans.close();
	if (session != null) {
		session.close();
	container.deactivate();
The exception I've got is
[ERROR] Rollback in DBStore: org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Table ECORE_ECLASS not found; SQL statement:
INSERT INTO ecore_EClass(cdo_id, cdo_version, cdo_branch, cdo_created, cdo_revised, cdo_resource, cdo_container, cdo_feature, name, instanceClassName, instanceTypeName, ePackage, abstract, interface, cdo_set_instanceClassName, cdo_set_instanceTypeName, eAnnotations, eTypeParameters, eOperations, eStructuralFeatures, eGenericSuperTypes) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) [42102-117]
at org.eclipse.emf.cdo.server.internal.db.SmartPreparedStatementCache.createCachedPreparedStatement(SmartPreparedStatementCache.java:84)
at org.eclipse.emf.cdo.server.internal.db.SmartPreparedStatementCache.getPreparedStatement(SmartPreparedStatementCache.java:43)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchingClassMapping.writeValues(HorizontalBranchingClassMapping.java:602)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchingClassMapping.writeRevision(HorizontalBranchingClassMapping.java:804)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writeRevision(DBStoreAccessor.java:583)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writeRevisions(DBStoreAccessor.java:563)
at org.eclipse.emf.cdo.spi.server.StoreAccessor.doWrite(StoreAccessor.java:94)
at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:487)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:43)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:262)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:96)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:84)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:326)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:63)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:680)
Caused by: org.h2.jdbc.JdbcSQLException: Table ECORE_ECLASS not found; SQL statement:
at org.h2.message.Message.getSQLException(Message.java:105)
at org.h2.message.Message.getSQLException(Message.java:116)
at org.h2.message.Message.getSQLException(Message.java:75)
at org.h2.command.Parser.readTableOrView(Parser.java:4265)
at org.h2.command.Parser.readTableOrView(Parser.java:4245)
at org.h2.command.Parser.parseInsert(Parser.java:888)
at org.h2.command.Parser.parsePrepared(Parser.java:368)
at org.h2.command.Parser.parse(Parser.java:290)
at org.h2.command.Parser.parse(Parser.java:262)
at org.h2.command.Parser.prepareCommand(Parser.java:234)
at org.h2.engine.Session.prepareLocal(Session.java:415)
at org.h2.engine.Session.prepareCommand(Session.java:376)
at org.h2.jdbc.JdbcConnection.prepareCommand(JdbcConnection.java:1049)
at org.h2.jdbc.JdbcPreparedStatement.<init>(JdbcPreparedStatement.java:74)
at org.h2.jdbc.JdbcConnection.prepareStatement(JdbcConnection.java:233)
at org.eclipse.emf.cdo.server.internal.db.SmartPreparedStatementCache.createCachedPreparedStatement(SmartPreparedStatementCache.java:79)
24 more
I use CDO 4.1-RC3 (S20120605-0730).
Do I miss something?
Thank in advanced
Re: [EMF] [CDO] What is the proper way to commit EClass instance to CDO server? [message #891695 is a reply to message #891644] Mon, 25 June 2012 10:14 Go to previous messageGo to next message
Am 25.06.2012 14:03, schrieb Thanapol R.:
That's not needed. Ecore is always registered. In general generated models do not need to be registered with CDOSessions
if the extension registry is functional.
Make sure that the legacy mode is switched on:
assertTrue(trans.isLegacyModeEnabled());
> try {
> trans.commit();
> finally {
> trans.close();
That's implicitely done when the session is closed.
> session.close();
> Quote:
>> found;
And with the DBStore you need to set:
<property name="supportingEcore" value="true"/>
Does that help?
Cheers
/Eike
http://www.esc-net.de
>> SQL statement:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 24 more
> Thank in advanced
Re: [EMF] [CDO] What is the proper way to commit EClass instance to CDO server? [message #891798 is a reply to message #891644] Tue, 26 June 2012 00:03 Go to previous messageGo to next message
It works.
Thank you
Thanapol R.
Re: [EMF] [CDO] What is the proper way to commit EClass instance to CDO server? [message #891799 is a reply to message #891695] Tue, 26 June 2012 00:04 Go to previous message
It works.
Thank you
Thanapol R.
Previous Topic:[CDO] CDOResource.eResource() creates an infinite loop in EMF EditingDomains
Next Topic:Compatible EMF version for Eclipse 3.7.2 Indigo
Current Time: Fri Jul 25 11:10:27 EDT 2025
Powered by FUDForum. Page generated in 0.08433 seconds
