no uml file from kdm [message #891542] |
Mon, 25 June 2012 04:06  |
i am new to modico. i just creasted my first kdm file from a java project. now i want an uml model.
but the process of discovering uml from kdm stops without any result - the progress window "discovering model..." closes but no file is opened. (serialize =true and open file in editor is checked)
so how to get the uml? thx in advance
Re: no uml file from kdm [message #891653 is a reply to message #891551] |
Mon, 25 June 2012 08:14   |
thx for hint to error log,
the error is:
Cannot set feature uml!InterfaceRealization.contract to value org.eclipse.uml2.uml.internal.impl.ClassImpl@310d67bd (name: <unset>, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false) (org.eclipse.modisco.kdm.uml2converter_0.9.2.v201202151138)
with trace:
org.eclipse.m2m.atl.engine.vm.VMException: Cannot set feature uml!InterfaceRealization.contract to value org.eclipse.uml2.uml.internal.impl.ClassImpl@310d67bd (name: <unset>, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)
at A.__applyImplementsToInterfaceRealization(1 : NTransientLink;) : ??#26(KDMtoUML.atl[541:3-541:89])
local variables = {tgt=umlOutput!<notnamedyet>, src=kdmInput!<unnamed>, link=TransientLink {rule = 'ImplementsToInterfaceRealization', sourceElements = {src = kdmInput!<unnamed>}, targetElements = {tgt = umlOutput!<notnamedyet>}, variables = {}}, self=KDMtoUML : ASMModule}
local stack = [umlOutput!<notnamedyet>]
Java Stack:
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(ASMEMFModelElement.java:513)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:323)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation.java:173)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java:130)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java:78)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:251)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:357)
at org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:346)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:216)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:127)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:92)
at org.eclipse.modisco.util.atl.core.internal.AtlLaunchHelper.runTransformation(AtlLaunchHelper.java:194)
at org.eclipse.modisco.util.atl.core.internal.AtlLaunchHelper.runTransformation(AtlLaunchHelper.java:173)
at org.eclipse.modisco.kdm.uml2converter.internal.KdmToUmlConverter.getUML2ModelFromKDMModelWithCustomTransformation(KdmToUmlConverter.java:114)
at org.eclipse.modisco.kdm.uml2converter.internal.KdmToUmlConverter.getUML2ModelFromKDMModel(KdmToUmlConverter.java:79)
at org.eclipse.modisco.kdm.uml2converter.DiscoverUmlModelFromKdmModel.basicDiscoverElement(DiscoverUmlModelFromKdmModel.java:89)
at org.eclipse.modisco.kdm.uml2converter.DiscoverUmlModelFromKdmModel.basicDiscoverElement(DiscoverUmlModelFromKdmModel.java:1)
at org.eclipse.modisco.infra.discovery.core.AbstractDiscoverer.discoverElement(AbstractDiscoverer.java:93)
at org.eclipse.modisco.infra.discovery.core.AbstractModelDiscoverer.discoverElement(AbstractModelDiscoverer.java:183)
at org.eclipse.modisco.infra.discovery.ui.internal.actions.MoDiscoMenuSelectionListener.discovererElement(MoDiscoMenuSelectionListener.java:352)
at org.eclipse.modisco.infra.discovery.ui.internal.actions.MoDiscoMenuSelectionListener$1.run(MoDiscoMenuSelectionListener.java:115)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.ClassCastException: org.eclipse.uml2.uml.internal.impl.ClassImpl cannot be cast to org.eclipse.uml2.uml.Interface
at org.eclipse.uml2.uml.internal.impl.InterfaceRealizationImpl.eSet(InterfaceRealizationImpl.java:492)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1081)
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(ASMEMFModelElement.java:510)
... 26 more
[Updated on: Mon, 25 June 2012 08:16] by Moderator
FUDForum. Page generated in 0.27048 seconds
