Home » Eclipse Projects » Remote Application Platform (RAP) » TreeViewer and CUSTOM_VARIANT
TreeViewer and CUSTOM_VARIANT [message #88372] Mon, 19 May 2008 09:26 Go to next message
I can not set the treeviewers font color with custom variant.
I tried:
viewer.getTree().setData(WidgetUtil.CUSTOM_VARIANT, "myStyle");
List.myStyle {
color: #ff0000;
and Tree.myStyle {
color: #ff0000;
This does not work.
Just using:
List {
color: #ff0000;
Works perfectly.
Markus
Re: TreeViewer and CUSTOM_VARIANT [message #88577 is a reply to message #88372] Mon, 19 May 2008 12:37 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Markus,
thanks for the hint. I opened bug 232825 and try to fix it asap.
Best regards, Ralf
Markus Krüger wrote:
> I tried:
> List.myStyle {
> color: #ff0000;
> and Tree.myStyle {
> color: #ff0000;
> This does not work.
> Just using:
> List {
> color: #ff0000;
> Works perfectly.
> Regards,
> Markus
Re: TreeViewer and CUSTOM_VARIANT AND IColorProvider [message #89156 is a reply to message #88577] Wed, 21 May 2008 07:55 Go to previous messageGo to next message
I also experience problems with the IColorProvider. Implementing this in
TreeProvider does also not work setting the foreground color.
Maybe this is the same problem?
Markus
"Ralf Sternberg" <rsternberg@innoopract.com> schrieb im Newsbeitrag
news:g0sabs$528$1@build.eclipse.org...
> Hi Markus,
> Best regards, Ralf
> Markus Kr
Re: TreeViewer and CUSTOM_VARIANT AND IColorProvider [message #89502 is a reply to message #89156] Fri, 23 May 2008 04:20 Go to previous messageGo to next message
Hi Markus,
this is very likely caused by bug 218420: [TreeItem]
setForeground(Color), setForeground(int, Color), setBackground(int,
Color) does not work
https://bugs.eclipse.org/bugs/show_bug.cgi?id=218420
I will have a look into these problems soon.
Ralf
Re: TreeViewer and CUSTOM_VARIANT [message #89953 is a reply to message #88577] Mon, 26 May 2008 06:35 Go to previous messageGo to next message
Fixed in CVS head. It is now possible to theme tree background and
foreground with a custom variant e.g. "mytree" using either using either
..mytree {
or
List.mytree {
This is because the Tree does not have back-/foreground colors of its
own yet and uses the List colors instead.
Cheers, Ralf
Re: TreeViewer and CUSTOM_VARIANT [message #89983 is a reply to message #89953] Mon, 26 May 2008 07:54 Go to previous messageGo to next message
Just tested it, but still does not take any effect...
I user:
List.navigation, *.navigation {
color: #ff0000;
background-color: #ffff00;
And
viewer.getTree().setData(WidgetUtil.CUSTOM_VARIANT, "navigation");
markus
news:g1e3q5$6ca$1@build.eclipse.org...
> .mytree {
> or
> List.mytree {
> This is because the Tree does not have back-/foreground colors of its own
> Cheers, Ralf
Re: TreeViewer and CUSTOM_VARIANT [message #89999 is a reply to message #89983] Mon, 26 May 2008 09:57 Go to previous messageGo to next message
Hi Markus,
> I user:
> color: #ff0000;
> And
This should work now. Can you please checkout again, my commit was
somewhat delayed (13:21)?
Regards, Ralf
Re: TreeViewer and CUSTOM_VARIANT [message #90014 is a reply to message #89999] Mon, 26 May 2008 10:17 Go to previous messageGo to next message
Hi Ralf,
now it works, thanks for fixing.
Markus
news:g1efl1$qdr$1@build.eclipse.org...
> Hi Markus,
> Markus Kr
Re: TreeViewer and CUSTOM_VARIANT AND IColorProvider [message #90489 is a reply to message #89502] Wed, 28 May 2008 05:49 Go to previous messageGo to next message
Hi Ralf,
when do you think will this be fixed? I need this really bad.
Markus
news:g15up7$9bk$1@build.eclipse.org...
> Hi Markus,
> Markus Kr
Re: TreeViewer and CUSTOM_VARIANT AND IColorProvider [message #90683 is a reply to message #90489] Thu, 29 May 2008 04:34 Go to previous messageGo to next message
Hi Markus,
I'm sorry, but this issue is related to a problem with the underlying
tree implementation and cannot easily be fixed in 1.1. The problem is
that TreeItem colors would override selection and disabled colors. After
the 1.1 release we'll be going to make a fresh start with the tree which
will make this problem obsolete.
Regards, Ralf
>> Hi Markus,
>> this is very likely caused by bug 218420: [TreeItem] setForeground(Color),
>> setForeground(int, Color), setBackground(int, Color) does not work
>> Best regards,
>> Ralf
Re: TreeViewer and CUSTOM_VARIANT AND IColorProvider [message #90745 is a reply to message #90683] Thu, 29 May 2008 05:50 Go to previous message
OK, thanks for the info. Keep uip the work, you guys are doing a very good
job.
Markus
news:g1lpqa$t3l$1@build.eclipse.org...
> Hi Markus,
> Markus Kr
Previous Topic:ENTER key on treeviewer and tableviewer
Next Topic:Theme files in CSS format
Current Time: Sat Aug 30 21:07:24 EDT 2025
Powered by FUDForum. Page generated in 0.08207 seconds
