Error in Localization? [message #890231] |
Thu, 21 June 2012 10:22  |
it seems, that there is an Error/Bug in the Localization.
In my report I use 2 property files with texts. One is in english, and one in german. So in most cases everything works fine. My PC is in german, so usually eclipse uses the german locales. Then i edit the settings, and changed it to english. In the report, and the parameter, everything is in english, beside the Parameter group. That's the only thing, which uses the text from the german properties file.
After this i deployed it to the server for testing. The server is in english, so normally the english texts are used. then i added the parameter "__locale=de" to the URL. All texts are in german. besides the parameter group. This is english (the same for the helptext of the parameter group.
In the next step i tried to create a new parameter group... the same... also in a new report. Everywhere the same.
Do you think its a configuration mistake? Or is there perhaps a bug in BIRT? I am using Version 3.7.2
Dnns
Edit: I've got a further question: How can i have influence in the "default" *.properties-file? i ask. because i tried a locale, which doesn't exist on the server (i used __locale=ru, but ther is no *_ru.properties). Instead of using the servers locale, it uses german.
[Updated on: Thu, 21 June 2012 10:35] by Moderator
Re: Error in Localization? [message #890313 is a reply to message #890231] |
Thu, 21 June 2012 17:09   |
I believe this was a bug that just got fixed about a week ago:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=365139
Jason
On 6/21/2012 10:22 AM, Dnns . wrote:
> thing, which uses the text from the german properties file. After this
> Dnns
FUDForum. Page generated in 1.26087 seconds
