Home » Modeling » TMF (Xtext) » [Solved] Xtext 2.2.1 project build stucks at "Validate resources"
[Solved] Xtext 2.2.1 project build stucks at "Validate resources" [message #890025] Wed, 20 June 2012 12:04 Go to next message
I have a hugh Xtext 2.2.1 project and the build process repeatly stucks at "Validate resources". The process bar for "Build Project" just stays the same for hours.
Can somebody give me a hint whats going wrong here?
BTW: The project has a language definition with about 150 gramar items. The code generator consists of about 40 Xtend2 classes (~650 kB of Xtend2 code).
Jonatan
[Updated on: Fri, 22 June 2012 12:08] by Moderator
Re: Xtext 2.2.1 project build stucks at "Validate resources" [message #890189 is a reply to message #890025] Thu, 21 June 2012 08:02 Go to previous messageGo to next message
I have just tried Eclipse Juno RC1 with Xtext 2.3M7 => same effects.
Jonatan
Re: Xtext 2.2.1 project build stucks at "Validate resources" [message #890300 is a reply to message #890189] Thu, 21 June 2012 15:57 Go to previous messageGo to next message
Is it when building the Xtend code or when executing it? If your Xtend
code contains a lot of closures with type inference for the parameters,
it can really help to declare the types explicitly.
Did you try to (significantly) increase heap memory?
Am 21.06.12 14:02, schrieb Jonatan Antoni:
> Hello,
> Regards,
> Jonatan
Re: Xtext 2.2.1 project build stucks at "Validate resources" [message #890387 is a reply to message #890300] Fri, 22 June 2012 03:46 Go to previous messageGo to next message
Hello Jan,
I do not really know what Eclipse is doing in the background while the project is building. I guess it is during building Xtend to Java code. Compiling and executing the resulting java code (our generator) is no problem.
Our Xtend code makes heavy use of closures, and I guess most time with type inference. I will try to remove the type inference.
I have tried heap sizes between 512m and 4096m. I guess more heap space helps a little bit, but not significantly.
Thx,
Jonatan
Re: Xtext 2.2.1 project build stucks at "Validate resources" [message #890593 is a reply to message #890387] Fri, 22 June 2012 12:09 Go to previous messageGo to next message
I have removed nearly all type inference from my project. Now it feels much faster.
Thx,
Jonatan
Re: Xtext 2.2.1 project build stucks at "Validate resources" [message #891521 is a reply to message #890593] Mon, 25 June 2012 03:12 Go to previous messageGo to next message
Jonatan,
yes, that is a unfortunate workaround. It is usually sufficient to
explicitly state the types of parameters in lambda expressions.
Sebastian
Am 22.06.12 18:09, schrieb Jonatan Antoni:
> Hello,
> much faster.
> Thx,
> Jonatan
Re: Xtext 2.2.1 project build stucks at "Validate resources" [message #892775 is a reply to message #891521] Fri, 29 June 2012 10:56 Go to previous messageGo to next message
Addition: The build also stucks at validate resources, when the generated xtext model classes are missing.
We do not commit the src-gen folder to the repository. Thus having a clean workspace, all those generated java classes are missing. Try to run the mwe2 workflow in order to let xtext generate these will trigger a workspace build. This ends up in the same problem.
The workaround here is just disable the Xtext project builder. Run the mwe2 workflow. Reenable the Xtext project builder afterwards.
Have you solved this issues with Juno?
Jonatan
Re: Xtext 2.2.1 project build stucks at "Validate resources" [message #892947 is a reply to message #892775] Mon, 02 July 2012 02:29 Go to previous messageGo to next message
Yes, compile problems are handled more gracefully in Juno. At least the
situation should be better than with former versions.
Sebastian
Am 29.06.12 16:57, schrieb Jonatan Antoni:
> Regards,
> Jonatan
Re: Xtext 2.2.1 project build stucks at "Validate resources" [message #892951 is a reply to message #892775] Mon, 02 July 2012 02:59 Go to previous message
Ooops, really? Could you file a bug for this?
> Regards,
> Jonatan
Previous Topic:[Newbie] Problem with grammar
Next Topic:gerrit for Xtext?
Current Time: Sun Jul 27 10:08:58 EDT 2025
Powered by FUDForum. Page generated in 0.08420 seconds
