Home » Modeling » EMF » Contributing adapter factories via extensions.
Contributing adapter factories via extensions. [message #890895] Sat, 23 June 2012 07:04 Go to next message
I'm extending a model using extension points as from Ed's article on BlogSpot:
"creating-children-you-didnt-know"
It works and my extension plugins can contribute new objects to the model.
The problem I'm having is with their label providers.
They don't seem to have any effect and the label contributions falls back on the ReflectiveItemProviderAdapterFactory.
After some debugging I think the problem might be with this extension point:
org.eclipse.emf.edit.itemProviderAdapterFactories
This is where my plugins contribute their item provider adapter factory.
And this is where the code it's supposed to use them:
ComposedAdapterFactory.getFactoryForTypes(Collection<?>) line: 241
- if (adapterFactoryDescriptorRegistry != null) ...
when it looks for a factory for my contributed types it doesn't find it in the main plugins ComposedAdapterFactory (which is OKs) but then it should go and look in the adapter factory descriptor registry where my plugins have (should have) registered their item provider adapter factory.
Instead the adapterFactoryDescriptorRegistry is always null.
Would anyone have a suggestion?
I'd like to debug the extension point but I can't think of a good way to do it.
I've put a break point on EMFEditPlugin at ComposedAdapterFactory.Descriptor.Registry getComposedAdapterFactoryDescriptorRegistry() but this is never called.
Note: it's only called by another EMF plugin which has an EMF editor. Specifically when creating the ComposedAdapterFactory:
adapterFactory = new ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Registry.INSTANCE);
but this has nothing to do with this problem.
Thanks for any help.
Frank
Re: Contributing adapter factories via extensions. [message #891184 is a reply to message #890895] Sun, 24 June 2012 04:03 Go to previous messageGo to next message
Frank,
Did you create your composed adapter factory with the registry as that
other editor does? It doesn't sound like you have and that's definitely
necessary.
On 23/06/2012 1:05 PM, Frank Goldwin wrote:
> BlogSpot:
> model.
> point:
> factory.
> to do it.
> Frank
Re: Contributing adapter factories via extensions. [message #891483 is a reply to message #891184] Mon, 25 June 2012 00:52 Go to previous message
Bingo! Thank you Ed, it works.
I'm putting here what I had and how I've fixed it for others to see.
Thank you!
Before:
// Create an adapter factory that yields item providers.
List factories = new ArrayList();
factories.add(new ResourceItemProviderAdapterFactory());
factories.add(new PlatformItemProviderAdapterFactory());
factories.add(new ReflectiveItemProviderAdapterFactory());
adapterFactory = new ComposedAdapterFactory(factories);
After:
// List factories = new ArrayList();
adapterFactory.addAdapterFactory(new ResourceItemProviderAdapterFactory());
adapterFactory.addAdapterFactory(new PlatformItemProviderAdapterFactory());
adapterFactory.addAdapterFactory(new ReflectiveItemProviderAdapterFactory());
Previous Topic:[CDO] CDOQuery / SessionManager memory leak?
Next Topic:CDO resources layout best practices
Current Time: Sun Aug 31 19:15:08 EDT 2025
Powered by FUDForum. Page generated in 0.04203 seconds
