Home » Archived » M2M (model-to-model transformation) » [ATL] Rule inheritance
[ATL] Rule inheritance [message #88943] Mon, 25 August 2008 12:33 Go to next message
Hello, I am working about the transformation SYSML -> UML. SysML is a
metamodel based on UML. I have a question.
My code is:
abstract rule package{
from package : SYSML!Package (package.oclIsTypeOf(SYSML!Package))
to paquetage : UML!Package ( -- Package
nestedPackage <- package.nestedPackage,
packagedElement <-package.packagedElement,
--ownedType <-package.ownedType,
packageMerge <- package.packageMerge,
nestingPackage <- package.nestingPackage,
-- Package -> Namespace
elementImport <- package.elementImport,
-- importedMember<-package.importedMember,
--member <- package.member,
--ownedMember <- package.ownedMember,
ownedRule <- package.ownedRule,
packageImport <- package.packageImport,
-- NamesSpace -> NamedElement
name <- package.name,
--qualifiedName <- package.qualifiedName,
visibility <- package.visibility,
-- NamedElement -> Element
ownedComment <- package.ownedComment
--ownedElement <- package.ownedElement
--owner <- package.owner
-- Package -> PackageableElement
do {
if (not package.ownedType.oclIsUndefined())
paquetage.ownedType <- package.ownedType;
paquetage.nestedPackage <- package.nestedPackage;
rule model extends package{
from model : SYSML!Model (model.oclIsTypeOf(SYSML!Model))
to modele : UML!Model( -- Model
viewpoint <- model.viewpoint
According to UML, the metaclass Model inherit of the metaclass Package
(Model -> Package).
In order to test my code, I insert a SysML diagram which contains a
model(m) which contains a package (p).
The transformation returns a UML diagram which contains a package (p), a
model (m) which contains a package (p).
I want the transformation returns a UML model(m) which contains a package
(p).
In fact, the same package is created 2 times... one time alone, and the
second time in the model.
How can I do in order to evoid this redundancy?
Monica.
Re: [ATL] Rule inheritance [message #89001 is a reply to message #88943] Tue, 26 August 2008 04:20 Go to previous messageGo to next message
Comments below :
> My code is:
Just a check: did you add the header
--@atlcompiler atl2006
on the top of the file ? According to that page :
http://wiki.eclipse.org/ATL_Language_Troubleshooter#Rule_inh eritance
Here, the filter will limit the use of this abstract rule to Package. So
you better have to remove it in order to extend the rule to Model.
> do {
A limitation of rule inheritance is that input pattern variables names
have to be the same in super and sub rules. So you need to use this
notation :
from package : SYSML!Model
viewpoint <- package.viewpoint
William
> (Model -> Package).
> package (p).
> Monica.
Re: [ATL] Rule inheritance [message #89095 is a reply to message #89001] Tue, 26 August 2008 06:11 Go to previous messageGo to next message
Thank you very much for your help William.
I corrected my code from your remarks :
-- @atlcompiler atl2006
module sysml2uml; -- Module Template
create OUT : UML from IN : SYSML;
to paquetage : UML!Package ( packagedElement <- p,
name <- package.name )
-- etc...
to modele : UML!Model( viewpoint <- package.viewpoint )
I obtain a document with this hierarch:
-<Model>
-<Package> diagSysML
but I expected a document with this hierach:
-<Model> diagSysML
- <Package> diagSysML
Could you please help me?
Monica.
Re: [ATL] Rule inheritance [message #89110 is a reply to message #89095] Tue, 26 August 2008 07:39 Go to previous messageGo to next message
What you want to do is to merge the "to" section of the two rules, in
order to have the "packagedElement <- p" link in the "to" section of the
model rule.
As for the "from" section, merging will be effective when the variables
have the same name.
So here is a rewrite of the model rule :
from package : SYSML!Model to paquetage : UML!Model( viewpoint <-
package.viewpoint )
William
> from package : SYSML!Package to paquetage : UML!Package (
> -- etc...
> from package : SYSML!Model to modele : UML!Model( viewpoint <-
> package.viewpoint )
> -<Model>
> -<Model> diagSysML
> Monica.
Re: [ATL] Rule inheritance... Thanks [message #89138 is a reply to message #89110] Tue, 26 August 2008 08:19 Go to previous message
Thank you very much William. It's work :
from package : SYSML!Package --(package.oclIsTypeOf(SYSML!Package))
to paquetage : UML!Package ( packagedElement <-package.packagedElement,
name <- package.name)
rule pack extends package{
from package : SYSML!Model (package.oclIsTypeOf(SYSML!Model))
to paquetage : UML!Model(viewpoint <- package.viewpoint)
I obtain this hierarch:
-<Model> diagSysml
-<Package> diagSysml
Monica.
Previous Topic:Can I do a helper that return a enumeration?
Next Topic:[ATL] refining and abstract metaclass
Current Time: Sat Jul 26 08:39:33 EDT 2025
Powered by FUDForum. Page generated in 0.04579 seconds
