Home » Newcomers » Newcomers » Building projects with different JDKs
Building projects with different JDKs [message #89076] Mon, 25 July 2005 17:55 Go to next message
I have two projects. One requires building using JDK 1.3.1_03. The other
requires building using JDK 1.4.2_07. It looks like I need to change the
default JDK each time I build one of the projects. Is there a way to
specify a specific JDK for compiling for each project? I'm coming from
JBuilder where I could specify a specific JDK for each project.
Thank you,
Don
Re: Building projects with different JDKs [message #89090 is a reply to message #89076] Mon, 25 July 2005 19:49 Go to previous messageGo to next message
Originally posted by: arvysoft.vtr.net
Don Leckie escribió:
> Hello,
> Thank you,
> Don
Don,
You'll find just that using project properties and check out the use of
default options.
Maybe you'll need to tell Eclipse where are those diferent JDK's
versions in order to select them from project properties. In that case
select windows / preferences / Installed JRE's and search
Ruben
Re: Building projects with different JDKs [message #89105 is a reply to message #89090] Mon, 25 July 2005 22:05 Go to previous message
Hi Ruben,
Thank you.
Don
<arvysoft@vtr.net> wrote in message news:dc3tqu$jer$2@news.eclipse.org...
> Don Leckie escribi
Previous Topic:WebTool Plugin
Next Topic:How to set SelectedColor on TableViewer?
Current Time: Sun Jul 27 00:34:52 EDT 2025
Powered by FUDForum. Page generated in 0.08641 seconds
