Ecore code generation strategy using inheritance [message #890475] |
Fri, 22 June 2012 07:40  |
Hi all,
I have a question regarding the code generation for multi-inheritance. I have an ecore
With three classes AClass, ASuperClass, BInterface. AClass has as super types: ASuperClass and BInterface. The classifiers look like this.
<eClassifiers xsi:type="ecore:EClass" name="AClass" eSuperTypes="#//BInterface #//ASuperClass"/>
<eClassifiers xsi:type="ecore:EClass" name="ASuperClass"/>
<eClassifiers xsi:type="ecore:EClass" name="BInterface" abstract="true" interface="true"/>
If I generate the code, AClassImpl looks like this:
public class AClassImpl extends EObjectImpl implements AClass { ... } and
public interface AClass extends ASuperClass, BInterface { ... }
I expected:
public class AClassImpl extends ASuperClassImpl implements AClass { ... } because ASuperClass contains some modified code.
I only got the last result by changing the order of the super types in AClass:
<eClassifiers xsi:type="ecore:EClass" name="AClass" eSuperTypes="#//ASuperClass #//BInterface"/>
Can anyone explain me, if this is expected behavior. After e few discussions with my colleagues I am not really sure anymore, if this is bug or feature.
Can anyone give me a hint?
Mark
Re: Ecore code generation strategy using inheritance [message #890498 is a reply to message #890475] |
Fri, 22 June 2012 08:31  |
Mark,
Comments below.
On 22/06/2012 7:40 AM, Mark Hoffmann wrote:
> Hi all,
> I have an ecore
> I expected:
> AClass:
> is bug or feature.
As you've noticed, it will generate the base class choice purely
depending on the order of the eSuperTypes.
Perhaps the generator could be a little smarter in this particular case,
but it's trivial for you to order the inheritance to produce the result
you want.
> Regards,
> Mark
FUDForum. Page generated in 0.04359 seconds
