Home » Eclipse Projects » BPMN 2.0 Modeler » BPMN2 Modeller update site failing
BPMN2 Modeller update site failing [message #889946] Wed, 20 June 2012 07:01 Go to next message
The bpmn2 modeller update site is failing to install the bpmn2 modeller, due to not finding the update site for Graphiti 0.8.1.
The Graphiti update site for 0.8.1 has been moved to archive :
archive.eclipse.org/graphiti/updates/0.8.1/
I have tried installing the above and then retrying the install, but to no success.
For reference here is the error message :
Unable to read repository at https :// hudson.eclipse.org/hudson/job/bpmn2-nightly/ws/org.eclipse.bpmn2.site/target/site/content.xml.
sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
No repository found at http :// download.eclipse.org/graphiti/updates/0.8.1/.
Unable to read repository at https :// repository.sonatype.org/content/repositories/forge-sites/m2e-extras/0.14.0/N/0.14.0.201109270543/content.xml.
Thanks.
PS. please note I had to add spaces to the urls to bypass the no-links for new user requirement
Re: BPMN2 Modeller update site failing [message #889987 is a reply to message #889946] Wed, 20 June 2012 09:42 Go to previous messageGo to next message
Hi Mare,
Thanks for reporting this - I'll look into it ASAP.
Bob
Re: BPMN2 Modeller update site failing [message #890079 is a reply to message #889987] Wed, 20 June 2012 19:04 Go to previous messageGo to next message
Please keep us posted. Any update yet?
[Updated on: Thu, 21 June 2012 11:47] by Moderator
Re: BPMN2 Modeller update site failing [message #890263 is a reply to message #890079] Thu, 21 June 2012 12:20 Go to previous messageGo to next message
I just tried installing on a fresh copy of eclipse indigo (3.7.2) and it worked (the installer grabbed graphiti version 0.8.2 from the indigo update site).
On helios (3.6.2) I had to install graphiti 0.8.2 first from here: http://download.eclipse.org/graphiti/updates/0.8.2, and that worked also.
Maybe y'all need to update your graphiti bits to 0.8.2?
HTH,
Bob
Re: BPMN2 Modeller update site failing [message #890274 is a reply to message #890263] Thu, 21 June 2012 13:49 Go to previous messageGo to next message
No change on Helios, it throws the 403 Forbidden: //download.eclipse.org/graphiti/updates/0.8.2
It was trying to read the 0.8.2/site.xml in Helios. Not sure how it worked out for you?
Re: BPMN2 Modeller update site failing [message #890278 is a reply to message #890274] Thu, 21 June 2012 13:51 Go to previous messageGo to next message
Uhhhh...beats me <shrug> I just tried this link again and I'm seeing the graphiti update site just fine. Are you behind a firewall that's preventing access to this site?
Re: BPMN2 Modeller update site failing [message #890283 is a reply to message #890278] Thu, 21 June 2012 14:16 Go to previous messageGo to next message
The link works just fine but as I mentioned Helios is trying to access //download.eclipse.org/graphiti/updates/0.8.2/site.xml which does not exist?
[Updated on: Thu, 21 June 2012 16:17] by Moderator
Re: BPMN2 Modeller update site failing [message #890491 is a reply to message #890283] Fri, 22 June 2012 08:18 Go to previous messageGo to next message
Using eclipse 3.6.2 (helios) I tried Help->Install New Software... and entered http://download.eclipse.org/graphiti/updates/0.8.2 in the "Work with:" text box. Eclipse finds the update site (Graphiti) and successfully installs version 0.8.2. I don't know what else to try to get it to fail...
Re: BPMN2 Modeller update site failing [message #908160 is a reply to message #890491] Tue, 04 September 2012 17:09 Go to previous message
Thats a lot of replies Smile, I am thinking the same.
Previous Topic:Error opening bpmn file
Next Topic:Eclipse deletes Choreography file on Save
Current Time: Sun Jul 27 11:13:44 EDT 2025
Powered by FUDForum. Page generated in 0.06538 seconds
