error using UML as input [message #887559] |
Sat, 16 June 2012 16:54  |
I'm trying to use ATL plugin, but I'm getting the following error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Could not find model element Model from UML
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.ASM.registerOperations(ASM.java:243)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:195)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch(EMFVMLauncher.java:139)
at uml2metamodelRC.Uml2metamodel.doUml2metamodel(Uml2metamodel.java:165)
at uml2metamodelRC.Uml2metamodel.main(Uml2metamodel.java:80)
Caused by: org.eclipse.m2m.atl.engine.emfvm.ASM$SignatureParsingException: Could not find model element Model from UML
at org.eclipse.m2m.atl.engine.emfvm.ASM.parseTypeInternal(ASM.java:414)
at org.eclipse.m2m.atl.engine.emfvm.ASM.parseType(ASM.java:378)
at org.eclipse.m2m.atl.engine.emfvm.ASM.registerOperations(ASM.java:240)
... 5 more
I'm using an UML file as metamodel in and an Ecore file as metamodel out.
I tried change sending a URL instead of UML metamodel, however the error still occurring.
So, what could I do to resolve it?
Re: error using UML as input [message #890087 is a reply to message #887559] |
Wed, 20 June 2012 23:19   |
Hi, Fernanda,
You will probably get better help about ATL on the ATL forum than on
the UML2 forum. This doesn't seem likely to be specific to the UML
metamodel, as such.
Christian
On 2012-06-16 20:54:12 +0000, Fernanda R.F. said:
> Java Stack:
> at
> at
> Caused by:
> ... 5 more
> Thanks
FUDForum. Page generated in 0.05996 seconds
