Home » Newcomers » Newcomers » Eclipse Visual Editor
Eclipse Visual Editor [message #88867] Sun, 24 July 2005 08:51 Go to next message
Originally posted by: bjorn.kleist.theolit.se
I’m a new user of Eclipse 3.1 and have tried to use the extra feature
Visual Editor. I start creating a new Java project. Then I try to create a
new Visual Class. Then I get an error message:
Error trying to set a new file in editor.
Reason: An internal error occurred during “ Create Remote VM for Visual
Editor for Java”
Is there any special trix to create a visual class?
Bjorn
Re: Eclipse Visual Editor [message #88972 is a reply to message #88867] Mon, 25 July 2005 11:51 Go to previous messageGo to next message
Originally posted by: ralkire.pdxinc.com
I have the same problem.
An internal error occurred during: "Create Remote VM for Visual Editor for
Java".
Java".
tried to access method
org.eclipse.pde.internal.core.WorkspaceModelManager.getWorks pacePluginModel(...)
If you find out what is wrong here please notify me.
"Bjorn Kleist" <bjorn.kleist@theolit.se> wrote in message
news:56c3c557a0a5100c063450862f59e099$1@www.eclipse.org...
> I
Re: Eclipse Visual Editor [message #89016 is a reply to message #88972] Mon, 25 July 2005 13:16 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Robert, make you've installed the Eclipse SDK, not just the runtime +
JDT. This error occurs because you do not have PDE installed.
- Jeff
> Java".
> Java".
> Thanks
Re: Eclipse Visual Editor [message #89031 is a reply to message #88867] Mon, 25 July 2005 13:19 Go to previous message
Bjorn, what version of VE and its required plug-ins did you install?
Please try installing VE 1.1, GEF 3.1 and EMF 2.1. If you continue to
get errors, please post the contents of your workspace's .metadata/.log
file to the newsgroup.
Hope this helps,
- Jeff
Bjorn Kleist wrote:
> I�m a new user of Eclipse 3.1 and have tried to use the extra feature
> a new Visual Class. Then I get an error message:
> Reason: An internal error occurred during � Create Remote VM for Visual
> Editor for Java�
> Bjorn
Previous Topic:web service
Next Topic:Building Eclipse 3.1 on FreeBSD 5.4
Current Time: Sat Nov 08 00:29:23 EST 2025
Powered by FUDForum. Page generated in 0.08281 seconds
