Why EModelElement doesn't inherit from EObject? [message #890288] |
Thu, 21 June 2012 14:47  |
Hello everybody,
I realized that since at least Indigo release, EModelElement doesn't inherit from EObject element in the Metamodel. Nevertheless, in the generated code EModelElement extends from EObject.
That's a problem, due to for instance XPand transformations doesn't work fine with this change. To solve this problem in XPand, I needed to change eContainer() calls by eContainer. In other words: access directly to the attribute instead of using the function.
Maybe there're other parts of code or transformations where this is a big problem.
Is it correct or is it a bug? If it's a bug, maybe it could be resolved in the Juno final release?
I create a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=383265
Thanks a lot.
Marc
FUDForum. Page generated in 0.07026 seconds
