Home » Newcomers » Newcomers » Scrapbook Bug(Error using scrapbbok to inspect)
Scrapbook Bug [message #889699] Tue, 19 June 2012 09:43 Go to next message
I am new to Eclipse and Java and formally from a VB background. I am following a tutorial good tutorial by Mark Dexter on the sourceforge link on Eclipse. (I am unable to post the link)
On lesson 3 it asks to highlight 2+2 in the Scrapbook and "inspect" the code but I just receive an error box stating "Unable to launch scrapbook VM". If I click on the details button it provides further information;
Cannot connect to VM
socket closed
Then in the console view the output is;
ERROR: transport error 202: connect failed: Connection refused
ERROR: JDWP Transport dt_socket failed to initialize, TRANSPORT_INIT(510)
JDWP exit error AGENT_ERROR_TRANSPORT_INIT(197): No transports initialized [../../../src/share/back/debugInit.c:690]
FATAL ERROR in native method: JDWP No transports initialized, jvmtiError=AGENT_ERROR_TRANSPORT_INIT(197
Can someone assist please.
Thanks in advance
Alan
Re: Scrapbook Bug [message #889888 is a reply to message #889699] Wed, 20 June 2012 03:23 Go to previous messageGo to next message
On 19.06.2012 15:43, Alan Farroll wrote:
> Hello,
> information;
> socket closed
Check whether your firewall blocks the connection.
Dani
> Thanks in advance
> Alan
Re: Scrapbook Bug [message #889940 is a reply to message #889888] Wed, 20 June 2012 06:17 Go to previous messageGo to next message
Hi Dani,
Thanks for your response.
Can you give a bit more information on this because I found some other information on the Internet about the firewall, but some suggest it is a setting actually on the Eclipse application, while others say it is a certain port number.
However, my organisation have our PC's setup where we cannot change Firewall settings and the Firewall On\Off options are disabled with the Off setting selected.
Any other help would be appreciated
Thanks you
Alan
Re: Scrapbook Bug [message #890124 is a reply to message #889940] Thu, 21 June 2012 04:12 Go to previous messageGo to next message
On 20.06.2012 12:17, Alan Farroll wrote:
> Hi Dani,
It's not a fixed port but just one that's free at that point and it
would only be on your localhost. If this is blocked you're doomed.
Dani
> Thanks you
> Alan
Re: Scrapbook Bug [message #890209 is a reply to message #890124] Thu, 21 June 2012 09:18 Go to previous messageGo to next message
Hi Dani,
As with my other problem, having my organisation allow the specific Java function to be not blocked by the organisation firewall has solved this.
Thanks again
Alan
Re: Scrapbook Bug [message #1235927 is a reply to message #889699] Sat, 25 January 2014 13:11 Go to previous message
hi
alan
i am facing the same problem.
can you plz tell how you solved it
Previous Topic:Find/Replace with Regex
Next Topic:Eclipse can't import Phonegap projects
Current Time: Fri Jul 18 10:11:36 EDT 2025
Powered by FUDForum. Page generated in 0.10392 seconds
