[Solved] Xtext 2.2.1 project build stucks at "Validate resources" [message #890025] |
Wed, 20 June 2012 12:04  |
I have a hugh Xtext 2.2.1 project and the build process repeatly stucks at "Validate resources". The process bar for "Build Project" just stays the same for hours.
Can somebody give me a hint whats going wrong here?
BTW: The project has a language definition with about 150 gramar items. The code generator consists of about 40 Xtend2 classes (~650 kB of Xtend2 code).
Jonatan
[Updated on: Fri, 22 June 2012 12:08] by Moderator
Re: Xtext 2.2.1 project build stucks at "Validate resources" [message #892951 is a reply to message #892775] |
Mon, 02 July 2012 02:59  |
Ooops, really? Could you file a bug for this?
Am 29.06.12 16:57, schrieb Jonatan Antoni:
> Addition: The build also stucks at validate resources, when the
> generated xtext model classes are missing.
> We do not commit the src-gen folder to the repository. Thus having a
> clean workspace, all those generated java classes are missing. Try to
> run the mwe2 workflow in order to let xtext generate these will trigger
> a workspace build. This ends up in the same problem.
> The workaround here is just disable the Xtext project builder. Run the
> mwe2 workflow. Reenable the Xtext project builder afterwards.
> Have you solved this issues with Juno?
> Regards,
> Jonatan
FUDForum. Page generated in 0.04150 seconds
