Equinox in clustered server env [message #88942] |
Wed, 30 May 2007 09:41  |
Originally posted by: viy.net.gmail.com
Hi all,
our team needs to develop common infrastructure for extensible J2EE
application. The "infrastructure" delivers common application logic,
interfaces, etc. and should provide way for extending itself by adding
extensions developed by customer side or other development team.
The whole application may be considered as UI-free, so all pluggable
components will ship only logic (non-UI) code.
The target deployment env for the application is JBoss 4 cluster.
We decided:
* to choose Equinox as plug-in framework
* to use Equinox HTTP ServletBridge web-app as packaging method for, at
least, our base infrastructure logic (it is also split into several
Equinox plugins) In other words, we just reassemble bridge.war with our
basic plugins inside and will deploy the WAR-file on server.
My questions are:
1. Did we choose right method to build such a pluggable server-side
application?
2. Especially, is Equinox HTTP ServletBridge appropriate for packaging
the application? Are there any other better methods to deploy
Equinox-enabled app on the server?
3. If we will use Equinox HTTP ServletBridge, how to "hot" add new
plugin to already running application? "Hot" means "without stopping the
application". I guess that default bridge packaging isn't suitable for
hot-adding-- plugins reside inside WAR-file in WEB-INF\eclipse\plugins
dir. And yet another question: how to make possible the plugin-adding be
cluster-wide? I have no any ideas on this point at the moment :(
4. Is it possible to use all powerful features (JMX, JDBC, JNDI, etc.)
provided by J2EE server (JBoss in our case) from inside of our plugin
running inside OSGi/Equnox framework running inside Equinox HTTP bridge
WAR? Is the usage transparent or we need to do something special to use
the features?
Thanks in advance.
Re: Equinox in clustered server env [message #89018 is a reply to message #88942] |
Wed, 30 May 2007 18:08   |
"Eugene Voytitsky" <viy.net@gmail.com> wrote in message
news:f3juv1$g4a$1@build.eclipse.org...
> Hi all,
> We decided:
> My questions are:
> application?
This is subjecive of course however I think OSGi in general and Equinox in
particular provide the ideal base for building this style of application.
> 2. Especially, is Equinox HTTP ServletBridge appropriate for packaging the
> application? Are there any other better methods to deploy Equinox-enabled
> app on the server?
Your packaging approach looks correct.
Ideally you'd want to package a smaller core set of bundles in your WAR
files and then add others you need dynamically however that requires a
management agent and provisioning strategy.
> 3. If we will use Equinox HTTP ServletBridge, how to "hot" add new plugin
> dir.
This would normally be the job of a management agent.Equinox as a platform
certainly supports this use-case however there is not currently an
out-of-the-box solution. If you want to take a look at this problem you
might "start" by looking at the console and then build your own.
This is doable however again you would have to handle the hot distribution
and synchronization yourself. The appserver will only cluster what you have
in the webapp.
> the features?
JMX and JDBC work transparently. JNDI works transparently for most resources
however it's not transparent for "java:comp/env" lookups as these are scoped
by the webapps context class loader. To get at these resources (at least for
the moment) you'd have to set the thread context class loader first to the
BridgeServlet's class loader.
HTH
-Simon
Re: Equinox in clustered server env [message #89103 is a reply to message #89074] |
Thu, 31 May 2007 16:16  |
> If I understand right the solution will look like:
> main web-app (actually just a reassembled HTTP bridge.was) with our core
> functionality (also realized as plugins) deployed on server in ordinary
> fashion. web-app starts our logic by auto-starting our plugin(s).
> Code in our main plugin starts to watch at some dir (say /extensions) and
> when found that new extension-plugin appears or old extension-plugin has
> changed then the main logic propagates the change set among the all
> cluster nodes. And all cluster nodes refreshes Equinox runtime by
> starting_new/restarting the extension-plugin.
> Right?
That sounds workable. There are of course lots of different ways to do this.
> And console app is good example of how to makes these refreshing
> dynamically. Right?
I suggest looking at the console as a starting point mainly so that you can
experiment with sorts of behaviours involved when your platform is dynamic.
If you dig a little deeper it might also server as some example code for
interacting with the bundlecontext to install, uninstall, and refresh the
platform.
-Simon
FUDForum. Page generated in 0.05033 seconds
