[CDO] CDOResource.eResource() creates an infinite loop in EMF EditingDomains [message #890114] |
Thu, 21 June 2012 03:48  |
is there any reason CDOResource (the root CDOResource, cdoId=OID1) returns itself when you call its eResource() method?
This causes an infinite loop when EditingDomain from EMF Model Editors calls to getRoot(Object) method.
Some of code:
AdapterFactoryEditingDomain: implementation of EditingDomain
public Object getParent(Object object)
// If there is an adapter of the correct type...
IEditingDomainItemProvider editingDomainItemProvider =
(IEditingDomainItemProvider)
adapterFactory.adapt(object, IEditingDomainItemProvider.class);
return
editingDomainItemProvider != null ?
editingDomainItemProvider.getParent(object) :
null;
public Object getRoot(Object object)
Object result = object;
for (Object parent = getParent(object); parent != null; parent = getParent(parent))
result = parent;
return result;
ItemProviderAdapter: implementation of IEditingDomainItemProvider
EObject eObject = (EObject)object;
Object result = eObject.eContainer();
if (result == null)
result = eObject.eResource();
return result;
The eObject.eResource() execution over CDOResource Object creates the infinite loop.
Re: [CDO] CDOResource.eResource() creates an infinite loop in EMF EditingDomains [message #891782 is a reply to message #890796] |
Mon, 25 June 2012 18:12  |
CDOResources, including the root Resource, are persistent EObjects, hence must be contained in a Resource. For all "normal" CDOResourceNodes that are not contained in a CDOResourceFolder that is the (invisible) root resource.
It is logical than a normal CDOResource (or CDOResource subFolder) return its CDOResource parent, included the "invisible" root resource. But for me it is not logical that the root parent container is not null.
So you can do CDOObject.eContainer().eContainer().eContainer().eContainer()... at infinitum because root CDOResource.eContainer() returns its own instance.
Have you tried to deploy the org.eclipse.emf.cdo.edit plugin? CDOResourceItemProvider has this method:
* Returns the parent of the argument CDOResource
* @ADDED
* @since 2.0
CDOResource resource = (CDOResource)object;
if (resource.isRoot())
return resource.getResourceSet();
return resource.getFolder();
No, I have not. Do you try to say to me that if I put this plugin and register (me or itself at plugin start) the CDO Adapter Factory (I do not have access to the exact class name now), my EMF Edit implementation maybe adapt to CDOResourceItemProvider and not to ItemProviderAdapter (I suppose standard adaptation class from EObject)?
My reasoning: when the execution manages CDOObject (not CDOResource), they are adapted to ItemProviderAdapter to provide getParent() and when execution gets a CDOResource object, it is adapted to CDOResourceItemProvider getParent() implementation.
It strikes me that CDOResourceFolderItemProvider.getParent(Object) should be moved up to CDOResourceNodeItemProvider in order to work with the new CDOFileResources. Can you please submit a bugzilla?
I am very lazy to create an account in bugzilla buy tomorrow I expect to do it
[Updated on: Mon, 25 June 2012 18:42] by Moderator
FUDForum. Page generated in 0.05981 seconds
