Home » Modeling » Epsilon » Problem with namespaces(read attributes from different namespaces)
Problem with namespaces [message #890000] Wed, 20 June 2012 10:16 Go to next message
Hi there,
I want to read the xmi:id s of objects in my model. In case such an object does not have an attribute or reference called id, everything works fine by use of this code:
aui!`InterfaceType`.allInstances().first().`id`.println();
But if there is an Object which defines an id-attribute in its own namespace, I cannot read the xmi:id:
aui!`GroupingType`.allInstances().first().`id`.println();
So the first statement resolves to: "_9oArcHgFEeGEQaFIIY_fFA"
and the second to: "Visualisierung"
I use this model:
<InterfaceType ... xmi:id="_9oArcHgFEeGEQaFIIY_fFA" ...>
<grouping xmi:id="_EGHXUHgGEeGEQaFIIY_fFA" id="Visualisierung">
Is there any way to choose an attribute from a specific namespace?
Thanks in advance.
Lukas
Re: Problem with namespaces [message #890017 is a reply to message #890000] Wed, 20 June 2012 11:15 Go to previous messageGo to next message
I suspect that calling the id() operation instead will solve this i.e.
aui!InterfaceType.allInstances().first().id().println();
On a side note, identifiers need to be placed between `` only when they they are keywords e.g. b.`var` = 5;
Dimitris
Re: Problem with namespaces [message #890018 is a reply to message #890017] Wed, 20 June 2012 11:27 Go to previous messageGo to next message
Hi and thanks a lot. That works.
By the way. Is there any possibility to inspect an object, maybe to get all operations and properties of it?
Lukas
Re: Problem with namespaces [message #891233 is a reply to message #890018] Sun, 24 June 2012 07:39 Go to previous messageGo to next message
Hi Lukas,
You can retrieve all the properties of an EObject using its eClass() method e.g.
for (sf in x.eClass().eStructuralFeatures) {
sf.name.println();
There is no direct way to retrieve all the operations applicable to an EObject but if you really need to do this, you can create a Java tool [1] to interrogate the Epsilon runtime context. Please let me know if you'd like to do this and I can provide more details.
Dimitris
[1] http://www.eclipse.org/epsilon/examples/index.php?example=org.eclipse.epsilon.examples.tools (see sayHelloAsVariable method)
Re: Problem with namespaces [message #892894 is a reply to message #891233] Sun, 01 July 2012 11:03 Go to previous messageGo to next message
Hi Dimitris,
this already helped me alot, but I have one problem, I cannot solve.
By use of the structural features, I can get properties of an object, by use of the property name as a string.
This is the code.
property = object.eClass().dynamicGet(sf.featureId);
This often works, but if a certain property is marked as derived (or volatile) this method does not work, property won't be defined.
How can I get the value of such a derived feature?
Greetings
Lukas
[update]
It turns out, that nothing changes when I set markers derived, volatile, transient in the ecore-model to false.
Where can be the difference between my method above to access the property and the method, which is used in epsilon?
Just before someone asks. The property, I try to read is definitely existent in the model.
[Updated on: Sun, 01 July 2012 11:31] by Moderator
Re: Problem with namespaces [message #892912 is a reply to message #892894] Sun, 01 July 2012 16:01 Go to previous message
Hi Lukas,
Could you please put together a minimal example[1] so that I can investigate?
Dimitris
[1] http://eclipse.org/epsilon/doc/articles/minimal-examples/
Previous Topic:Global Variables in imported EOL
Next Topic:[EOL] Adapter Error The value of type
Current Time: Wed Jul 23 13:24:50 EDT 2025
Powered by FUDForum. Page generated in 0.07296 seconds
