Home » Modeling » Epsilon » how to set the property by only name?
how to set the property by only name? [message #889926] Wed, 20 June 2012 05:28 Go to next message
index.php/fa/10356/0/
as in the picture u can see two nodes have a connection between them.
node1 is aaa and node2 is ccc.
now if i select the transition line u can see the properties like bandwidth, name, source,target.
in source u can see is written real Node zzz. here aaa is node name and real Node in type of the node. same for target.
I want that source only shows the name aaa not the type.
so source should be aaa and target should be ccc only.
  • Attachment: 2.jpg
    (Size: 63.81KB, Downloaded 431 times)
[Updated on: Wed, 20 June 2012 05:28] by Moderator
Re: how to set the property by only name? [message #889955 is a reply to message #889926] Wed, 20 June 2012 07:54 Go to previous message
Hi iqbal Mising name,
This seems to be more of a GMF question than Epsilon related. However, I
think (but am not sure) you will find that the text shown in the
properties is based on what the toString method of the respective model
objects returns.
Steffen
On 20/06/2012 10:28, iqbal Mising name wrote:
> as in the picture u can see to nodes have a connection between then.
Previous Topic:[EWL] Wizards is not appearing in RCP Application
Next Topic:Concordance Indexing Builder freezes
Current Time: Wed Jul 23 05:43:42 EDT 2025
Powered by FUDForum. Page generated in 0.43777 seconds
