Home » Eclipse Projects » Linux Tools Project » gcov plugin - Invalid binary file error(gcov plugin related question)
gcov plugin - Invalid binary file error [message #841033] Tue, 10 April 2012 16:37 Go to next message
I'm trying to use the gcov eclipse plugin from the eclipse linuxtools group, under windows.
I successfully installed the gcov plugin v0.6.0.201203221532 under eclipse 3.7.2 with CDT 8.0.2
When I double click on one of the gcda or gcno files and select my win32/PE executable built using MinGW in the "Gcov - open coverage results..." dialogue box I get an error messing saying "Invalid binary file - xyz.exe is not a valid binary file."
Are only Linux executable files supported by this plugin? Or am I doing something wrong?
Re: gcov plugin - Invalid binary file error [message #842419 is a reply to message #841033] Thu, 12 April 2012 05:25 Go to previous messageGo to next message
The support for windows is limited.
It "should" work, but has not been heavily tested.
Is your computer 32bits or 64bits ?
Do you have any backtrace related to gcov in the <workspace>/.metadata/.log file ?
Re: gcov plugin - Invalid binary file error [message #848971 is a reply to message #842419] Wed, 18 April 2012 15:09 Go to previous messageGo to next message
Hello Xavier,
my operating system is a 32 bit Windows XP Professional SP3.
eclipse.buildId=M20120208-0800
java.version=1.6.0_31
Command-line arguments: -os win32 -ws win32 -arch x86
My .log file contains nothing related to gcov nor to the error messages I get.
Based on the source code this is the code snippet which fails, in OpenGCDialog::validateBinary():
IBinaryObject binary = STSymbolManager.sharedInstance.getBinaryObject(new Path(binValue));
if (binary == null) {
"binary" is null.
The path to my executable is "c:\workspace\gtest\bin\sample1_unittest.exe". The path should be correct as the file handle tells that my file exists.
I don't know if it matters or not but my executable is built using MinGW/GCC using the following command:
g++ -I./include -g -static -fprofile-arcs -ftest-coverage -Wall -Wextra -lpthread -lgcov bin/sample1.o bin/sample1_unittest.o bin/gtest_main.a -o ./bin/sample1_unittest
Re: gcov plugin - Invalid binary file error [message #889789 is a reply to message #848971] Tue, 19 June 2012 11:27 Go to previous messageGo to next message
I had the same problem, and I fixed it by changing my tool chain editor. I had mine set to Linux GCC, but I was using Cygwin. When I changed the toolchain to Cygwin GCC it worked.
Setting is Project Settings->C/C++ Build->Tool Chain Editor->Current Tool Chain
Re: gcov plugin - Invalid binary file error [message #889873 is a reply to message #889789] Wed, 20 June 2012 02:07 Go to previous message
Thank you Alex! This solved my issue too. You are a real life saver Smile
Previous Topic:noob trying to set up C++ IDE
Next Topic:1.0 released!
Current Time: Sat Jul 26 08:50:07 EDT 2025
Powered by FUDForum. Page generated in 0.12417 seconds
