Home » Eclipse Projects » Eclipse 4 » Menues not shown in wizard generated e4 application
Menues not shown in wizard generated e4 application [message #889753] Tue, 19 June 2012 10:36 Go to next message
I am trying out eclipse 4.2RC4. I added the e4 Tools via install new software. I generated my first e4 application using the eclipse 4 application project wizard.
When I run the project, the help menu with the about menuitem is not shown. Can anyone tell me why?
I then added an own menu into the menubar with one menu item that is shown but not enabled. the handler class has no canExcecute method. How do I enable that item?
Thank you.
Christian
Re: Menues not shown in wizard generated e4 application [message #889960 is a reply to message #889753] Wed, 20 June 2012 08:11 Go to previous messageGo to next message
You'll have to tell us exactly what you added? A HandledMenuItem, pointing to a command? Where was the handler defined?
A direct menu item?
PW
Re: Menues not shown in wizard generated e4 application [message #889966 is a reply to message #889753] Wed, 20 June 2012 08:35 Go to previous message
if you created the command and handler with API (not through the model editor) you may have to call E4Workbench.processHierarchy
See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=376254
Previous Topic:3.x plugins provided with the support of CSS in Eclipse 4?
Next Topic:Unzip of Eclipse4.2 64 bit fails
Current Time: Thu Jul 24 21:41:53 EDT 2025
Powered by FUDForum. Page generated in 0.19736 seconds
