Home » Language IDEs » ServerTools (WTP) » tomcat launcher problem - where to set classpath?
tomcat launcher problem - where to set classpath? [message #88594] Tue, 29 March 2005 22:07 Go to next message
Originally posted by: cliffresnick.yahoo.com
I'm getting ClassNotFound errors (bootstrap) on all my tomcat launchers.
I cannot find any place to set the classpath for the launcher so I
assume classpath is derived from the tomcat root directory (tried and
remaoved a trailing slah there). Can anyone please point out what I must
be missing?
Re: tomcat launcher problem - where to set classpath? [message #88933 is a reply to message #88594] Wed, 30 March 2005 10:53 Go to previous message
Try Run -> Run... and select the run configuration under "Apache
Tomcat". Examine the settings there to see what might be wrong. You
can also try deleting the run configuration and running the server again
to allow it to be recreated. This might clear something up. If not,
provide some detail about what you see there so we can try to determine
Larry
> be missing?
Previous Topic:CVS Label Decorators appearing several times in J2EE view?
Next Topic:Install Problems WTP1.0M3 on Eclipse3.1M5a
Current Time: Fri Nov 07 06:54:50 EST 2025
Powered by FUDForum. Page generated in 0.03405 seconds
