Home » Modeling » GMF (Graphical Modeling Framework) » How to use the side-affixed property?
| How to use the side-affixed property? [message #88768] |
Tue, 02 January 2007 11:28  |
Originally posted by: kalin.nakov.gmail.com
I need to display small squares attached to the border of a parent
symbol, the same as the ports in UML. I've heard that setting the
side-affixed property of the Node element in the gmfgraph file could do
the job. I have spent a lot of time on this with no success. What should
I do to make it working?
Thanks in advance,
Kalin
| Re: How to use the side-affixed property? [message #89778 is a reply to message #89394] |
Fri, 05 January 2007 14:11   |
--------------010602040200000906040102
Content-Type: text/plain; charset=UTF-7
I have created a separate example editor. Here is the situation:
* Without setting side-affixed property everything works fine
* If I set the side affixed property without a compartment everything
works fine
* If I add a compartment with a figure which is a child element of the
master rectangle, the appearance of the symbol is correct, but it is
attached at the upper left corner of the canvas and cannot be moved,
selected, also the whole canvas becomes unusable - no more elements can
be added, modified, etc..
* If I add a compartment with a figure which is not a child element of
the master rectangle, the canvas is editable, but I cannot add small
squares on the border of the master rectangle, because the compartment
figure is stretched and seems to overlap the border. In addition to that
the compartment is no longer collapsible, nevertheless the arrow shows
the opposite.
I cannot live without those compartments, so I desperately need to make
that working. Is there somewhere, anywhere any example on how to use
side-affixed borders of a symbol which has compartments? Attached is a
simple picture of what I want.
Thank you very much in advance!
Alex Shatalin wrote:
> Hello Kalin,
>> is a child of the big rectangle and visually it is ok. Unfortunately
>> now when I insert the big rectangle in the canvas it is stuck in the
>> upper left corner of the canvas and cannot be moved, resized or even
>> selected :-(
> I can suggest you to investigate this problem a bit more.. You can
> create simple mapping (without compartment and figure on the border) and
> generate code + create diagram. The if everything works ok you can add
> border figure.. And then compartment. as a result we'll be able to
> determine steps forcing you to this problem. BTW, I suggest you to
> remove diagram and create new one each time you modify .gmfmap ->
> .gmfgen models and regenerate the code since you are changing diagram
> structure and existing elements can start being incorrect..
> Alex Shatalin
Content-Type: image/gif;
name="what-i-want.gif"
Content-Disposition: inline;
filename="what-i-want.gif"
R0lGODlhQAHIAPcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
/wD//////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAz AAAzMwAzZgAz
mQAzzAAz/wBmAABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDM AADMMwDMZgDM
mQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMz ADMzMzMzZjMz
mTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPM ADPMMzPMZjPM
mTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2Yz AGYzM2YzZmYz
mWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bM AGbMM2bMZmbM
mWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kz AJkzM5kzZpkz
mZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nM AJnMM5nMZpnM
mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wz AMwzM8wzZswz
mcwzzMwz/8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zM AMzMM8zMZszM
mczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8z AP8zM/8zZv8z
mf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///M AP/MM//MZv/M
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAABAAcgAAAj/ AP8JHEiwoMGD
CBMqXMiwocOHECNKnEixosWLGDNq3Mixo8ePIEOKHEmypMmTKFOqXMmypcuX MGPKnEmzps2b
OHPq3Mmzp8+fQIMKHUq0qNGjSJMqXcq0qdOnUKNKnUq1qtWrWLNq3cq1q9ev YMOKHUu2rNmz
aNOqXcu2rdu3cOPKnUu3rt27ePPq3cu3r9+/gAMLHky4sOHDiBMrXsy4sePH kCNLnky5suXL
mDNr3sy5s+fPoEPLRUG6tOnTqFOrXs26tevXsGPLnv1aMwrRAm9n1i2a92Xf oIFXFu6Z+GTj
nJFHVm67OW7mj6Fjlt6YumXri7HL1H6Qu03vh8G7/xQ/kPx25+cJ6i79j317 0rnb54Y//zZ7
3vbfl6cP3LxF/4IBiJF7761XnnwIysffgfgh2OCCDRa4n4AQUfiXhRT1ZxB9 DpqW4Gkfhmhg
fCCqVxCGDKHIl4oSEUhgfA6eeKCJJDIIo4IbcviiSSzq1eNEGj54Y35Dikij fjjWeKRKP+LV
pEbu8bfghFQiKSJ+HM70pF1b7hRhT13SFSZOvo15kZlxoekjeqGp+ZabTrLJ E4gUwpmhnF7K
CGVQdrLVZ0QaSqigi1LCt2OeuwFF55UxCqnkT3+qFelDQXo4on2W2qgonjoF qaeBgSYJKac5
eaokqJqK6tOkaLHa0KKCXv9aX5FZzklqcrdu5qpZu76Z66/R4Zbgb8L2Spax bSErlrJrMQsW
bdBGK+201FYLLbDTNefsWdt6hWmb2g6La6IjdtZtV0SKe5xrlBF57lbMvVtV fvJqFW+7Vmar
UL1TpZvovviauxC/UhEM78ABV2jtwrIhde9xLQpl8JLdJUypxA4jDDGgGB/1 sGTc8TvxjAmN
7FTIHRtV28YVpryUyf1GzOfJ2Oq5aVMwFyzzzUzlHBXKM+NcM8Vg0vxvy0H3 PDTJowp99MVJ
v7z0jU0r/bRDIhutL9I8S331qy4r5TNUQHct9tTq2ur01lCbndTYT5Vdtdds Yx3222hnvTax
HEfRffbXKd6dMeAauz143WD7jTfhACt+ON9cz/034oE77nHegl/OeMkMd87u 3tcVizbIoy9X
OmRwaw3u5qcXlvpVr1vdW+uOxU736pQLzPrutXvu++/AB8+asMQXb/zxyCev /PLMN+/889BH
L/301Fdv/fXYZ6/99tx37/334Icv/vjkl2/++einr/767Lfv/vvwxy///PTX b//9+Oev//78
9+///wAMoAAHSMACGvCACEygAhfIwAY68IEQjKAEJ0jBClrwghjMoAY3yMEO erAlAQEAOw==
--------------010602040200000906040102--
| Re: How to use the side-affixed property? [message #89807 is a reply to message #89778] |
Fri, 05 January 2007 15:24   |
Originally posted by: vcciubot.uwaterloo.ca
Your side affixed element - called BorderItem by the run time - should be
attached to the top level node. That node should extends from
AbstractBorderedShapeEditPart. To get rid of some of the symptoms you
describe, I had to override the following methods:
protected NodeFigure createMainFigure() {
NodeFigure figure = new DefaultSizeNodeFigure(getMapMode().DPtoLP(40),
getMapMode().DPtoLP(40));
figure.setLayoutManager(new StackLayout());
contentPane = new BlockFigure();
figure.add(contentPane);
ConstrainedToolbarLayout layout = new ConstrainedToolbarLayout();
contentPane.setLayoutManager(layout);
return figure;
public IFigure getContentPane() {
if (contentPane != null) {
return contentPane;
return super.getContentPane();
* our superclass messes this up, not returning the correct content pane
* (non-Javadoc)
* @see org.eclipse.gmf.runtime.diagram.ui.editparts.AbstractBordere dShapeEditPart#getContentPaneFor(org.eclipse.gmf.runtime.dia gram.ui.editparts.IGraphicalEditPart)
protected IFigure getContentPaneFor(IGraphicalEditPart editPart) {
if (editPart instanceof IBorderItemEditPart) {
return getBorderedFigure().getBorderItemContainer();
} else {
return getContentPane();
I've got code that does that, but it hasn't been generated automatically
and it uses GMF 1, maybe Alex can say whether there have been API changes
in the runtime.
If you're interested I can send you some code you could compare to the
generated one to see where the problem is.
cheers,
vlad
On Fri, 05 Jan 2007 21:11:11 +0200, Kalin Nakov wrote:
> works fine
> the opposite.
>> Hello Kalin,
>>> selected :-(
>> generate code create diagram. The if everything works ok you can add
>> Alex Shatalin
| Re: How to use the side-affixed property? [message #90040 is a reply to message #89778] |
Sat, 06 January 2007 12:08   |
Hello Kalin,
> can be added, modified, etc..
Any exceptions in .log file or console? Can you add empty compartment first?
So, there will be "master rectangle" with child reference to "small rectangle"
(affixed) and empty compartment.
Looks like an incorrect configuration. Compartments are just a way to “visually
group” child elements of the node. This means, you can have master rectangle
with several child node references. In addition several compartments can
present in this “master rectangle”. Child nodes could be grouped and visualized
inside corresponding compartments by attaching them to the compartment element
in .gmfmap model. In other words, compartment can reference only child nodes
of it’s parent node.
Side-affixed node is a node located on the border of “master rectangle”.
This not should not be included into any compartments of the “master rectangle”.
AFAIK there should be an audit warning you about this constraint.
> make that working. Is there somewhere, anywhere any example on how to
> use side-affixed borders of a symbol which has compartments? Attached
There should be a way to make it working. ;-) First you can try Vlad’s suggestions.
As a sample of elements located on border I can suggest you to have a look
on “org.eclipse.mdt.uml2.diagram.*” plugins. These plugins are created using
GMF and AFAIK side-affixed children are used there together with compartments
(with additional border in main figure).
Alex Shatalin
| Re: How to use the side-affixed property? [message #90294 is a reply to message #89807] |
Mon, 08 January 2007 04:07  |
That solution works pretty well. Thank you very much!
Kalin
> return figure;
> return contentPane;
> * (non-Javadoc)
> } else {
> in the runtime.
> cheers,
> vlad
>> Hi,
>> works fine
>> the opposite.
>>> Hello Kalin,
>>>> selected :-(
>>> Alex Shatalin
Current Time: Tue Nov 04 17:47:59 EST 2025
Powered by FUDForum. Page generated in 0.04039 seconds
