Home » Eclipse Projects » JFace » TableWrapLayout on JFace Dialog(Placing controls on Dialog using TableWrapLayout and TableWrapData)
TableWrapLayout on JFace Dialog [message #888560] Mon, 18 June 2012 05:36 Go to next message
I have a button which should open up a dialog when the user clicks on it.
button.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
TestDialog testDialog = new TestDialog(container.getShell());
testDialog.setPolicy(policy);
testDialog.open();
I am trying to use TableWrapLayout inside TestDialog, like below
protected Control createDialogArea(Composite parent) {
//Composite composite = new Composite(parent, 0); NOT WORKING
TableWrapLayout tableWrapLayout = new TableWrapLayout();
tableWrapLayout.numColumns = 3;
tableWrapLayout.verticalSpacing = 1;
tableWrapLayout.horizontalSpacing = 1;
TableWrapData twd = new TableWrapData(TableWrapData.FILL_GRAB);
parent.setLayout(tableWrapLayout);
parent.setLayoutData(twd);
Button button = new Button(parent, SWT.NONE);
button.setText("test");
return parent;
which gives me a ClassCastException... org.eclipse.ui.forms.widgets.TableWrapData
cannot be cast to org.eclipse.swt.layout.GridData
Am I missing something here?
Aravind
Re: TableWrapLayout on JFace Dialog [message #888566 is a reply to message #888560] Mon, 18 June 2012 05:47 Go to previous messageGo to next message
the parent composite you are setting TableWrapData on, has a parent with the GridLayout. Look at the createDialogArea method javadoc.
Re: TableWrapLayout on JFace Dialog [message #888626 is a reply to message #888566] Mon, 18 June 2012 07:47 Go to previous messageGo to next message
So.. That concludes that TableWrapLayout can't be used within JFace Dialog as such.
Re: TableWrapLayout on JFace Dialog [message #888694 is a reply to message #888626] Mon, 18 June 2012 09:58 Go to previous message
No, just the composite returned from the createDialogArea must have the GridData as a layout data. This composite itself can use whatever layout you need. Something like that:
Composite composite = (Composite) super.createDialogArea(parent);
composite.setLayout(tableWrapLayout);
Composite content = new Composite(composite, SWT.NONE);
content.setLayout(new FillLayout());
content.setLayoutData(twd);
return composite;
Previous Topic:TableViewer with custom cell editor
Next Topic:Scroll Bar in JFace Dialog
Current Time: Mon Nov 03 18:38:47 EST 2025
Powered by FUDForum. Page generated in 0.03989 seconds
