Home » Modeling » TMF (Xtext) » How to limit the global scope
How to limit the global scope [message #888471] Mon, 18 June 2012 02:55 Go to next message
Hi all,
the documentation suggests to bind an own implementation of
IResourceDescription.Manager in order to limit the exported objects in a
certain resource.
The javadoc of DefaultResourceDescriptionManager however says that
customisation should be done by implementing a custom
IDefaultResourceDescriptionStrategy.
Is there a example somewhere demonstrating how this looks like in practice?
In my use case I want only a certain type being exported, all other named
elements should only be visible within the local resource.
Thanks for your help,
Axel
Re: How to limit the global scope [message #888477 is a reply to message #888471] Mon, 18 June 2012 03:10 Go to previous messageGo to next message
Hi simply straight forward overriding
defaultresourcedescriptionstrategy.createaEObjectDescriptions doesnt
work ?
Re: How to limit the global scope [message #888505 is a reply to message #888477] Mon, 18 June 2012 03:59 Go to previous messageGo to next message
Hi Christian,
thanks I will try it out. Just wanted to ensure it is the correct entrypoint
to hook into :-)
> work ?
Re: How to limit the global scope [message #888511 is a reply to message #888505] Mon, 18 June 2012 04:05 Go to previous message
Works perfectly, thanks again!
Previous Topic:How to add copyright headers to generated sources
Next Topic:Java heap space
Current Time: Wed Jul 23 01:56:59 EDT 2025
Powered by FUDForum. Page generated in 0.04691 seconds
