Unit test fails to find file that's in source path, unless added to classpath [message #886780] |
Fri, 15 June 2012 12:06  |
I have a unit test (integration test, really) which uses the Spring runner and needs to find my applicationContext.xml, which resides in src/main/webapp/WEB-INF. I have several tests that require this.
In my Maven POM, it works fine because I set the "additionalClasspathElements" to include this directory.
In Eclipse, I thought I could get this to work by simply adding "src/main/webapp/WEB-INF" as a source directory. It doesn't appear to be working. The only thing that's working is editing each run configuration for each test and adding that directory to the classpath. It's annoying that I have to do this for every test's run configuration.
Is there a better way to do this?
Re: Unit test fails to find file that's in source path, unless added to classpath [message #887484 is a reply to message #887364] |
Sat, 16 June 2012 14:01  |
Stephan Herrmann wrote on Sat, 16 June 2012 09:33David M. Karr wrote on Fri, 15 June 2012 18:06In Eclipse, I thought I could get this to work by simply adding "src/main/webapp/WEB-INF" as a source directory.
Why source folder? This would require that all your xml are correctly copied to some binary folder that's on the classpath, since source folders do not directly contribute to the classpath. In combinations of JDT and m2e unexpected things may happen regard such copying (check whether the source folder has any exlusion filters!).
Maybe adding the folder as a "Class Folder" works more straight-forward?
Yes, that makes more sense, and I verified that that works.
PS: for indepth advice regarding web applications the WTP forum will likely give better results.
I considered that, but this issue really has nothing to do with the fact that it's a web application.
FUDForum. Page generated in 0.04287 seconds
