Home » Eclipse Projects » Eclipse Platform » Internet Connection Freezes Eclipse(Connecting to Internet on Windows XP freezes Eclipse)
Internet Connection Freezes Eclipse [message #887067] Fri, 15 June 2012 22:30 Go to next message
Version: Indigo (re-downloaded/installed today, June 15)
OS: Windows XP
When I start up Eclipse and attempt to do anything that connects to the internet (check for updates, Market place, download new server connectors, etc) Eclipse freezes. According to Windows Task Manager there is no activity at all.
There are several related facts:
- Firefox/IE work fine even when Eclipse is frozen, so it is not the network.
- The Network proxy in Eclipse is set to Native. I also tried Direct with the same result.
- This is a dual-boot machine and the same version of Eclipse on linux is fine.
- After Eclipse freezes I have to kill it, then I cannot re-start it until after rebooting the OS.
- I used to be able to connect with no problem.
The one obvious thing that has changed between "used to work" and now is that I replaced my (simple) cable modem with a full network router. The setup of the router might have something to do with this, but I don't know what settings might be causing the problem.
Can you think of something I can look at?
Does Eclipse use anything other than standard http for connecting?
What settings in a network router might affect the ability to get to the internet?
This is preventing cross-browser testing, so any suggestions will be much appreciated.
Glenn
Re: Internet Connection Freezes Eclipse [message #887854 is a reply to message #887067] Sun, 17 June 2012 04:41 Go to previous messageGo to next message
I suggest you to start JConsole or VisualVM and try to investigate
Eclipse instance to see what happens wrong.
Maybe some threads are blocked by I/O. My personal experience is that
Eclipse P2 sites are, let me to say, "dead-slow" (modem speed).
Libor
> OS: Windows XP
> network.
> is fine.
> internet?
> much appreciated.
> Thanks
> Glenn
Re: Internet Connection Freezes Eclipse [message #888836 is a reply to message #887854] Mon, 18 June 2012 13:29 Go to previous messageGo to next message
Libor,
Thanks for the reply. The problem is not just slow response from Eclipse websites: I let it run over-night and still got no response. Of course that might be a contributing cause to the lockup, as I think you were suggesting.
I was hoping that an expert could advise on how Eclipse internet access is different than Firefox/IE access so I wouldn't have to debug Eclipse code myself. If you have any suggestions along that line please pass them on.
Glenn
Re: Internet Connection Freezes Eclipse [message #889370 is a reply to message #888836] Tue, 19 June 2012 03:04 Go to previous messageGo to next message
On 18.06.2012 19:29, G Griffin wrote:
> Libor,
Check the proxy settings (Window > Preferences > General > Network
Connections) and also your firewall(s).
Dani
> Thanks
> Glenn
Re: Internet Connection Freezes Eclipse [message #889456 is a reply to message #888836] Tue, 19 June 2012 04:47 Go to previous messageGo to next message
Eclipse (or strictly speaking SWT toolkit) uses Gecko (Mozilla renderee)
on Linux, IE on Windows, and Safari on Mac OS. It's just a browser
embedded into SWT window and should be different in any way.
Also, you may try to troubleshoot HTTP traffic with something like
Wireshark.
Libor
On 06/18/2012 07:29 PM, G Griffin wrote:
> Libor,
> suggesting.
> them on.
> Thanks
> Glenn
Re: Internet Connection Freezes Eclipse [message #892758 is a reply to message #887067] Fri, 29 June 2012 09:52 Go to previous message
Thanks for your suggestions. As far as I can tell my settings are the same in Eclipse as in IE (no proxy) so I'm at a loss for what to do to fix this.
Fortunately I've managed to by-pass the problem by copying the appropriate plugin jars from my Linux system onto my Windows Eclipse setup so I can proceed with working.
Thanks for the help
Previous Topic:Eclipse 3.8 M7 unstable on Linux?
Next Topic:unable to create session bean in dynamic web project
Current Time: Fri Oct 31 23:27:10 EDT 2025
Powered by FUDForum. Page generated in 0.03815 seconds
